CustomDictionary 属性 (ActiveX)
指定要使用的自定义词典(如果有)。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 要使用的自定义词典。 言论此特性包含 AutoCAD 任务的自定义字典的驱动器、路径和文件名。 例子VBA: Sub Example_CustomDictionary()
' CustomDictionary. It then changes the value, and finally
Dim currCustomDictionary As String
Dim newCustomDictionary As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current CustomDictionary value
currCustomDictionary = preferences.Files.CustomDictionary
MsgBox "The current value for CustomDictionary is " & currCustomDictionary, vbInformation, "CustomDictionary Example"
' Change the value for CustomDictionary
newCustomDictionary = "TestCustomDictionary.cus"
preferences.Files.CustomDictionary = newCustomDictionary
MsgBox "The new value for CustomDictionary is " & newCustomDictionary, vbInformation, "CustomDictionary Example"
' Reset CustomDictionary to its original value
preferences.Files.CustomDictionary = currCustomDictionary
MsgBox "The CustomDictionary value is reset to " & currCustomDictionary, vbInformation, "CustomDictionary Example"
可视化 LISP: (vl-load-com)
(defun c:Example_CustomDictionary()
;; CustomDictionary. It then changes the value, and finally
;; Retrieve the current CustomDictionary value
(setq currCustomDictionary (vla-get-CustomDictionary (vla-get-Files preferences)))
(alert (strcat "The current value for CustomDictionary is " currCustomDictionary))
;; Change the value for CustomDictionary
(setq newCustomDictionary "TestCustomDictionary.cus")
(vla-put-CustomDictionary (vla-get-Files preferences) newCustomDictionary)
(alert (strcat "The new value for CustomDictionary is " newCustomDictionary))
;; Reset CustomDictionary to its original value
(vla-put-CustomDictionary (vla-get-Files preferences) currCustomDictionary)
(alert (strcat "The CustomDictionary value is reset to " currCustomDictionary))
GMT+8, 2026-11-13 17:21
