Center 属性 (ActiveX)
指定圆弧、圆、椭圆、视图或视口的中心。 支持的平台:仅限 Windows 属性值只读:不 类型:变体(双打的三元素阵列) 表示对象中心的 3D 坐标。默认中心为 (0,0,0)。 视口、视图:视口和视图对象的中心是 2D 坐标。 言论![]() 例子VBA: Sub Example_Center()
Dim circObj As AcadCircle
Dim currCenterPt(0 To 2) As Double
Dim newCenterPt(0 To 2) As Double
Dim radius As Double
' Define the initial center point and radius for the circle
currCenterPt(0) = 20: currCenterPt(1) = 30: currCenterPt(2) = 0
radius = 3
' Create the circle in model space
Set circObj = ThisDrawing.ModelSpace.AddCircle(currCenterPt, radius)
ZoomAll
MsgBox "The center point of the circle is " & currCenterPt(0) & ", " & currCenterPt(1) & ", " & currCenterPt(2), vbInformation, "Center Example"
' Change the center point of the circle
newCenterPt(0) = 25: newCenterPt(1) = 25: newCenterPt(2) = 0
circObj.center = newCenterPt
circObj.Update
' Query the results of the new center position
' Notice the output from the center property is a variant
Dim centerPoint As Variant
centerPoint = circObj.center
MsgBox "The center point of the circle is " & centerPoint(0) & ", " & centerPoint(1) & ", " & centerPoint(2), vbInformation, "Center Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Center()
;; Define the initial center point and radius for the circle
(setq currCenterPt (vlax-3d-point 20 30 0)
radius 3)
;; Create the circle in model space
(setq circObj (vla-AddCircle modelSpace currCenterPt radius))
(vla-ZoomAll acadObj)
(alert (strcat "The center point of the circle is"
"\n" (rtos (nth 0 (vlax-safearray->list (vlax-variant-value currCenterPt)))) ", "
(rtos (nth 1 (vlax-safearray->list (vlax-variant-value currCenterPt)))) ", "
(rtos (nth 2 (vlax-safearray->list (vlax-variant-value currCenterPt))))
;; Change the center point of the circle
(setq newCenterPt (vlax-3d-point 25 25 0))
(vla-put-Center circObj newCenterPt)
(vla-Update circObj)
;; Query the results of the new center position
;; Notice the output from the center property is a variant
(setq centerPoint (vlax-variant-value (vla-get-Center circObj)))
"\n" (rtos (nth 0 (vlax-safearray->list centerPoint))) ", "
(rtos (nth 1 (vlax-safearray->list centerPoint))) ", "
(rtos (nth 2 (vlax-safearray->list centerPoint)))
GMT+8, 2026-11-13 13:27
