Blue 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 847| 评论: 0|原作者: admin|来自: AutoCAD
Blue 属性 (ActiveX)
指定“真彩色”的蓝色分量。
object.Blue
类型:AcCmColor
此属性应用于的对象。
只读:是的
类型:长
的蓝色分量,从 0-255 开始。AcCmColor
Sub Example_Blue()
    ' This example draws a line and returns the RGB values
    Dim color As AcadAcCmColor
    Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    color.SetRGB 80, 100, 244
    Dim line As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
    Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    ZoomAll
    line.TrueColor = color
    Dim retcolor As AcadAcCmColor
    Set retcolor = line.TrueColor
    MsgBox "Red = " & retcolor.Red & vbLf & _
           "Green = " & retcolor.Green & vbLf & _
           "Blue = " & retcolor.Blue
(defun c:Example_Blue()
    ;; This example draws a line and returns the RGB values
    (setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB color 80 100 244)
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    (setq line (vla-AddLine modelSpace startPoint endPoint))
    (vla-ZoomAll acadObj)
    (vla-put-TrueColor line color)
    (setq retcolor (vla-get-TrueColor line))
    (alert (strcat "Red = " (itoa (vla-get-Red retcolor))
                   "\nGreen = " (itoa (vla-get-Green retcolor))
                   "\nBlue = " (itoa (vla-get-Blue retcolor))
    (vlax-release-object color)
GMT+8, 2026-11-13 13:50
