Blocks 属性 (ActiveX)
获取图形的 Blocks 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Blocks()
' This example first finds the Blocks collection
' using the Blocks property. It then adds a new
' block to the Blocks collection.
Dim blkColl As AcadBlocks
Dim newBlock As AcadBlock
Dim insertionPnt(0 To 2) As Double
' Get the Blocks collection
Set blkColl = ThisDrawing.Blocks
' Define the insertion point for the new block
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
' Add the new block into the Blocks collection
Set newBlock = blkColl.Add(insertionPnt, "TEST")
MsgBox "A block called " & newBlock.name & " has been added to the blocks collection", vbInformation, "Blocks Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Blocks()
;; This example first finds the Blocks collection
;; using the Blocks property. It then adds a new
;; block to the Blocks collection.
;; Get the Blocks collection
(setq blkColl (vla-get-Blocks doc))
;; Define the insertion point for the new block
(setq insertionPnt (vlax-3d-point 0 0 0))
;; Add the new block into the Blocks collection
(setq newBlock (vla-Add blkColl insertionPnt "TEST"))
(alert (strcat "A block called " (vla-get-Name newBlock) " has been added to the blocks collection."))
GMT+8, 2026-11-12 12:26
