BigFontFile 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 684| 评论: 0|原作者: admin|来自: AutoCAD
指定与文本或属性关联的大字体文件的名称。
object.BigFontFile
类型:TextStyle
此属性应用于的对象。
只读:不
类型:字符串
大字体文件的名称。
此属性与该属性类似,只不过它用于指定亚洲语言的大字体文件。唯一有效的文件类型是 SHX。FontFile
此属性不能设置为空字符串。NULL
Sub Example_BigFontFile()
    ' BigFontFile. It then changes the value.
    Dim textStyle1 As AcadTextStyle
    Dim currBigFontFile As String
    Dim newBigFontFile As String
    Set textStyle1 = ThisDrawing.ActiveTextStyle
    ' Retrieve the current BigFontFile value
    currBigFontFile = textStyle1.BigFontFile
    MsgBox "The current value for BigFontFile is " & currBigFontFile, vbInformation, "BigFontFile Example"
    ' Change the value for BigFontFile
    newBigFontFile = "C:/AutoCAD/Fonts/bigfont.shx"
    textStyle1.BigFontFile = newBigFontFile
    MsgBox "The new value for BigFontFile is " & newBigFontFile, vbInformation, "BigFontFile Example"
(defun c:Example_BigFontFile()
    ;; BigFontFile. It then changes the value.
    (setq textStyle1 (vla-get-ActiveTextStyle doc))
    ;; Retrieve the current BigFontFile value
    (setq currBigFontFile (vla-get-BigFontFile textStyle1))
    (alert (if (= currBigFontFile "")
	       (strcat "There is not big font file assigned to this font.")
	       (strcat "The current value for BigFontFile is " currBigFontFile))
    ;; Change the value for BigFontFile
    (setq newBigFontFile (findfile "./Fonts/bigfont.shx"))
    (vla-put-BigFontFile textStyle1 newBigFontFile)
    (alert (strcat "The new value for BigFontFile is " newBigFontFile))
GMT+8, 2026-11-15 15:17
