AutoTrackingVecColor 属性 (ActiveX)
指定自动跟踪矢量的颜色。 支持的平台:仅限 Windows 属性值只读:不 类型:OLE_COLOR(常量)
言论此属性的默认颜色为 。vbWhite 例子VBA: Sub Example_AutoTrackingVecColor()
' This example reads and modifies the preference value that controls
' the color of the AutoTrack vector. When finished, this example
' resets the preference value back to its original value.
Dim ACADPref As AcadPreferencesDisplay
' Get the display preferences object
Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
originalValue = ACADPref.AutoTrackingVecColor
MsgBox "The AutoTrackingVecColor preference is: " & originalValue
' Modify the AutoTrackingVecColor preference by making it red
ACADPref.AutoTrackingVecColor = vbRed
newValue = ACADPref.AutoTrackingVecColor
MsgBox "The AutoTrackingVecColor preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoTrackingVecColor = originalValue
MsgBox "The AutoTrackingVecColor preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AutoTrackingVecColor()
;; This example reads and modifies the preference value that controls
;; the color of the AutoTrack vector. When finished, this example
;; resets the preference value back to its original value.
;; Get the Display preferences object
(setq ACADPref (vla-get-Display preferences))
(setq originalValue (vlax-variant-change-type (vla-get-AutoTrackingVecColor ACADPref) vlax-vbLong))
(alert (strcat "The AutoTrackingVecColor preference is: " (itoa (vlax-variant-value originalValue))))
;; Modify the AutoTrackingVecColor preference by making it red
(vla-put-AutoTrackingVecColor ACADPref (vlax-make-variant acRed 19))
(setq newValue (vlax-variant-change-type (vla-get-AutoTrackingVecColor ACADPref) vlax-vbLong))
(alert (strcat "The AutoTrackingVecColor preference has been set to: " (itoa (vlax-variant-value newValue))))
;; this preference in effect
(vla-put-AutoTrackingVecColor ACADPref (vlax-variant-change-type originalValue 19))
(alert (strcat "The AutoTrackingVecColor preference was reset back to: " (itoa (vlax-variant-value originalValue))))
GMT+8, 2026-11-13 17:22
