AutoSnapMarkerSize 属性 (ActiveX)
指定 AutoSnap 标记的大小。 支持的平台:仅限 Windows 属性值只读:不 类型:长 一个介于 1 到 20 之间的值,表示 AutoSnap 标记的大小(以像素为单位)。 言论没有其他评论。 例子VBA: Sub Example_AutoSnapMarkerSize()
' This example reads and modifies the preference value that controls
' the size of the AutoSnap marker. When finished, this example resets
' the preference value back to its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AutoSnapMarkerSize
MsgBox "The AutoSnapMarkerSize preference is: " & originalValue
' Modify the AutoSnapMarkerSize preference by setting it to 10
ACADPref.AutoSnapMarkerSize = 10
newValue = ACADPref.AutoSnapMarkerSize
MsgBox "The AutoSnapMarkerSize preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoSnapMarkerSize = originalValue
MsgBox "The AutoSnapMarkerSize preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AutoSnapMarkerSize()
;; This example reads and modifies the preference value that controls
;; the size of the AutoSnap marker. When finished, this example resets
;; the preference value back to its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-AutoSnapMarkerSize ACADPref))
(alert (strcat "The AutoSnapMarkerSize preference is: " (itoa originalValue)))
;; Modify the AutoSnapMarkerSize preference by setting it to 10
(vla-put-AutoSnapMarkerSize ACADPref 10)
(setq newValue (vla-get-AutoSnapMarkerSize ACADPref))
(alert (strcat "The AutoSnapMarkerSize preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-AutoSnapMarkerSize ACADPref originalValue)
(alert (strcat "The AutoSnapMarkerSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-11-12 12:29
