AutoSnapAperture 属性 (ActiveX)
切换 AutoSnap 光圈的显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 当您捕捉到对象时,AutoSnap 光圈显示在十字准线的中心。仅当启用了 AutoSnap 标记、磁贴或工具提示时,此选项才可用。 注意:此属性的值存储在 APBOX 系统变量中。
例子VBA: Sub Example_AutoSnapAperture()
' This example reads and modifies the preference value that controls
' the display of the AutoSnap aperture.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AutoSnapAperture
MsgBox "The AutoSnapAperture preference is set to: " & originalValue
' Modify the AutoSnapAperture preference by toggling the value
ACADPref.AutoSnapAperture = Not (originalValue)
newValue = ACADPref.AutoSnapAperture
MsgBox "The AutoSnapAperture preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoSnapAperture = originalValue
MsgBox "The AutoSnapAperture preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AutoSnapAperture()
;; This example reads and modifies the preference value that controls
;; the display of the AutoSnap aperture.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-AutoSnapAperture ACADPref))
(alert (strcat "The AutoSnapAperture preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the AutoSnapAperture preference by toggling the value
(vla-put-AutoSnapAperture ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-AutoSnapAperture ACADPref))
(alert (strcat "The AutoSnapAperture preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-AutoSnapAperture ACADPref originalValue)
(alert (strcat "The AutoSnapAperture preference was reset back to: " (if (= originalValue :vlax-true) "True" "false")))
GMT+8, 2026-11-12 12:39
