AltUnitsFormat 属性 (ActiveX)
指定除角度外的所有尺寸的备用单位的单位格式。 支持的平台:仅限 Windows 签名VBA: object.AltUnitsFormat
属性值只读:不 类型:枚举acDimUnits
言论此属性的初始值为 。acDimDecimal 注意:此属性将覆盖给定维度的 DIMALTU 系统变量的值。
例子VBA: Sub Example_AltUnitsFormat()
' uses AltUnitsFormat to cycle through some common unit formats
' for the alternate dimension
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
' Enable unit display of alternate units
dimObj.AltUnits = True
dimObj.AltUnitsFormat = acDimScientific ' Change format to Scientific
MsgBox "The alternate dimension units are now set to Scientific"
dimObj.AltUnitsFormat = acDimDecimal ' Change format to Decimal
MsgBox "The alternate dimension units are now set to Decimal"
dimObj.AltUnitsFormat = acDimArchitectural ' Change format to Architectural
MsgBox "The alternate dimension units are now set to Architectural"
dimObj.AltUnitsFormat = acDimWindowsDesktop ' Change format to Windows Desktop
MsgBox "The alternate dimension units are now set to Windows Desktop"
可视化 LISP: (vl-load-com)
(defun c:Example_AltUnitsFormat()
;; uses AltUnitsFormat to cycle through some common unit formats
;; for the alternate dimension
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5.12345678 5 0)
(vla-ZoomAll acadObj)
;; Enable unit display of alternate units
(vla-put-AltUnits dimObj :vlax-true)
(vla-put-AltUnitsFormat dimObj acDimScientific) ;; Change format to Scientific
(alert "The alternate dimension units are now set to Scientific.")
(vla-put-AltUnitsFormat dimObj acDimDecimal) ;; Change format to Decimal
(alert "The alternate dimension units are now set to Decimal.")
(vla-put-AltUnitsFormat dimObj acDimArchitectural) ;; Change format to Architectural
(alert "The alternate dimension units are now set to Architectural.")
(vla-put-AltUnitsFormat dimObj acDimWindowsDesktop) ;; Change format to Windows Desktop
(alert "The alternate dimension units are now set to Windows Desktop.")
GMT+8, 2026-11-15 19:43
