AltTextSuffix 属性 (ActiveX)
2024-5-18 18:21| 发布者: admin| 查看: 662| 评论: 0|原作者: admin|来自: AutoCAD
指定除 angular 之外的所有尺寸类型的备用尺寸测量的后缀。
object.AltTextSuffix
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:字符串
备用维度的后缀。
此属性的初始值为“”。
若要关闭已建立的后缀,请将此属性设置为等于单个句点 (.)。
注意:此属性将覆盖给定维度的 DIMAPOST 系统变量的值。
Sub Example_AltTextSuffix()
   ' uses AltTextSuffix to allow the user to change the text suffix for the
   ' alternate dimension
    Dim dimObj As AcadDimAligned
    Dim suffix As String
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Enable alternate unit display
    dimObj.AltUnits = True
    ' Allow the user to change the text suffix for the alternate dimension
    suffix = InputBox("Enter a new text suffix for the alternate dimension", "Alternate Dimension Suffix", ":SUFFIX")
    dimObj.AltTextSuffix = suffix   ' Commit changes to suffix
    ' Read back and display the alternate dimension text suffix
    suffix = dimObj.AltTextSuffix
    If suffix <> "" Then
        MsgBox "The suffix of the alternate dimension has been changed to: " & suffix
    Else
        MsgBox "The suffix of the alternate dimension has been removed"
    End If
(defun c:Example_AltTextSuffix()
    ;; uses AltTextSuffix to allow the user to change the text suffix for the
    ;; alternate dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    ;; Enable alternate unit display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-ZoomAll acadObj)
    ;; Allow the user to change the text suffix for the alternate dimension
    (setq suffix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text suffix for the alternate dimension: "))
    (vla-put-AltTextSuffix dimObj suffix)   ;; Commit changes to suffix
    ;; Read back and display the alternate dimension text suffix
    (setq suffix (vla-get-AltTextSuffix dimObj))
    (if (/= suffix "")
        (alert (strcat "The suffix of the alternate dimension has been changed to: " suffix))
        (alert "The suffix of the alternate dimension has been removed")
GMT+8, 2026-11-13 13:29
