ActiveViewport 属性 (ActiveX)
指定图形的活动视口。 支持的平台:仅限 Windows 言论只有在将视口重置为活动视口后,对当前活动视口所做的更改才会可见。若要重置活动视口,只需使用更新的视口对象调用此属性即可。 使用该属性可确定视口当前是否处于活动状态。StatusID 您可以循环访问现有视口以查找特定视口。为此,请首先使用该属性确定所需视口所在的视口配置的名称。此外,如果视口配置已拆分,则可以通过 和 属性来标识配置上的每个单独视口。NameLowerLeftCornerUpperRightCorner and 属性表示视口在显示器上的图形位置。这些属性定义如下(以四向拆分为例):LowerLeftCornerUpperRightCorner ![]() 视口 1— = (0, .5), = (.5, 1)LowerLeftCornerUpperRightCorner 视口 2— = (.5, .5), = (1, 1)LowerLeftCornerUpperRightCorner 视口 3— = (0, 0), = (.5, .5)LowerLeftCornerUpperRightCorner 视口 4— = (.5, 0), = (1, .5)LowerLeftCornerUpperRightCorner 例子VBA: Sub Example_ActiveViewport()
' This example returns the current viewport.
' It creates a new viewport and makes it active, and
' Then it splits the viewport into four windows.
' It then takes one of the four windows, and splits that
' window horizontally into half.
Dim currViewport As AcadViewport
Dim newViewport As AcadViewport
' Returns current viewport of active document
Set currViewport = ThisDrawing.ActiveViewport
MsgBox "The current viewport is " & currViewport.name, vbInformation, "ActiveViewport Example"
' Create a new viewport and make it active
Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
ThisDrawing.ActiveViewport = newViewport
MsgBox "The new active viewport is " & newViewport.name, vbInformation, "ActiveViewport Example"
' Split the viewport in four windows
newViewport.Split acViewport4
' Make the newly split viewport active
' Note that current drawing layout will show four windows.
' However, only one of the windows will be active.
' The following code sets the lower-left corner window
' to be the active window and then splits that
' window into two horizontal windows.
Dim entry
For Each entry In ThisDrawing.Viewports
If entry.name = "TESTVIEWPORT" Then
Dim lowerLeft
lowerLeft = entry.LowerLeftCorner
If lowerLeft(0) = 0 And lowerLeft(1) = 0 Then
Set newViewport = entry
Exit For
End If
End If
Next
newViewport.Split acViewport2Horizontal
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveViewport()
;; This example returns the current viewport.
;; It creates a new viewport and makes it active, and
;; Then it splits the viewport into four windows.
;; It then takes one of the four windows, and splits that
;; window horizontally into half.
;; Returns current viewport of active document
(setq currViewport (vla-get-ActiveViewport doc))
(alert (strcat "The current viewport is " (vla-get-Name currViewport)))
;; Create a new viewport and make it active
(setq viewports (vla-get-Viewports doc))
(setq newViewport (vla-Add viewports "TESTVIEWPORT"))
(vla-put-ActiveViewport doc newViewport)
(alert (strcat "The new active viewport is " (vla-get-Name newViewport)))
;; Split the viewport in four windows
(vla-Split newViewport acViewport4)
;; Make the newly split viewport active
;; Note that current drawing layout will show four windows.
;; However, only one of the windows will be active.
;; The following code sets the lower-left corner window
;; to be the active window and then splits that
;; window into two horizontal windows.
(vlax-for each-viewport viewports
(if (= (vla-get-Name each-viewport) "TESTVIEWPORT")
(progn
(setq lowerLeft (vla-get-LowerLeftCorner each-viewport))
(if (and (= (vlax-safearray-get-element (vlax-variant-value lowerLeft) 0) 0)
(= (vlax-safearray-get-element (vlax-variant-value lowerLeft) 1) 0)
(setq newViewport each-viewport)
(vla-Split newViewport acViewport2Horizontal)
GMT+8, 2026-11-13 13:44
