ActiveSelectionSet 属性 (ActiveX)
获取图形的活动选择集。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_ActiveSelectionSet()
Dim sset As AcadSelectionSet
' The following example returns current selection set from current drawing
Set sset = ThisDrawing.ActiveSelectionSet
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveSelectionSet()
;; The following example returns the current selection set from the current drawing
(setq sset (vla-get-ActiveSelectionSet doc))
GMT+8, 2026-11-13 13:39
