ActiveLinetype 属性 (ActiveX)
指定绘图的活动线型。 支持的平台:仅限 Windows 言论图形中必须已存在指定的线型。若要添加新的线型,请使用该方法。Add 例子VBA: Sub Example_ActiveLinetype()
' This example finds the current linetype. It then sets
' the new linetype to be the first entry in the linetype
' collection that is not equal to the current linetype.
' Finally, it resets the active linetype to the original
' setting.
Dim currLineType As AcadLineType
Dim newLineType As AcadLineType
' Find the current LineType of the active document
Set currLineType = ThisDrawing.ActiveLinetype
MsgBox "The current linetype is " & currLineType.name, vbInformation, "ActiveLinetype Example"
' Set the current Linetype to anything else in the collection
Dim entry
Dim found As Boolean
For Each entry In ThisDrawing.Linetypes
If StrComp(entry.name, currLineType.name, 1) <> 0 Then
Set newLineType = entry
found = True
Exit For
End If
Next
If found Then
ThisDrawing.ActiveLinetype = newLineType
MsgBox "The new linetype is " & newLineType.name, vbInformation, "ActiveLinetype Example"
' Reset the linetype to the previous setting
ThisDrawing.ActiveLinetype = currLineType
MsgBox "The active linetype is reset to " & currLineType.name, vbInformation, "ActiveLinetype Example"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveLinetype()
;; This example finds the current linetype. It then sets
;; the new linetype to be the first entry in the linetype
;; collection that is not equal to the current linetype.
;; Finally, it resets the active linetype to the original
;; setting.
;; Find the current LineType of the active document
(setq currLineType (vla-get-ActiveLinetype doc))
(alert (strcat "The current linetype is " (vla-get-Name currLineType)))
;; Set the current Linetype to anything else in the collection
(setq newLineType nil)
(setq found :vlax-false)
(vlax-for each-linetype (vla-get-Linetypes doc)
(if (and (/= (vla-get-Name each-linetype) (vla-get-Name currLineType)) (/= found :vlax-true))
(progn
(setq newLineType each-linetype)
(setq found :vlax-true)
(if (= found :vlax-true)
(progn
(vla-put-ActiveLinetype doc newLineType)
(alert (strcat "The new linetype is " (vla-get-Name newLineType)))
;; Restore the previous linetype
(vla-put-ActiveLinetype doc currLineType)
(alert (strcat "The active linetype is restored to " (vla-get-Name currLineType)))
GMT+8, 2026-11-13 14:03
