Split 方法 (ActiveX)
将视口拆分为给定的视图数。 支持的平台:仅限 Windows 签名VBA: object.Split NumWins
返回值 (RetVal)无返回值。 言论尽管已调用该方法,但在使用该属性使视区处于活动状态之前,不会显示更改。即使视口在调用 之前处于活动状态,这也是必需的。SplitActiveViewportSplit 视口不必处于活动状态即可使此方法正常工作,但是,必须将其重置为活动状态才能查看此方法的结果。 例子VBA: Sub Example_Split()
' This example creates a new viewport and makes it active.
' Then it splits the viewport into four windows.
' It then takes one of the four windows, and splits that
' window horizontally in half.
Dim newViewport As AcadViewport
' Create a new viewport and make it active
Set newViewport = ThisDrawing.Viewports.Add("TESTVIEWPORT")
ThisDrawing.ActiveViewport = newViewport
' Split the viewport in four windows
newViewport.Split acViewport4
' Make the newly split viewport active
' Note that current drawing layout will show four windows.
' However, only one of the windows will be active.
' The following code sets the lower-left corner window
' to be the active window and then splits that
' window into two horizontal windows.
Dim entry
For Each entry In ThisDrawing.Viewports
If entry.name = "TESTVIEWPORT" Then
Dim lowerLeft
lowerLeft = entry.LowerLeftCorner
If lowerLeft(0) = 0 And lowerLeft(1) = 0 Then
Set newViewport = entry
Exit For
End If
End If
Next
newViewport.Split acViewport2Horizontal
可视化 LISP: (vl-load-com)
(defun c:Example_Split()
;; This example creates a new viewport and makes it active.
;; Then it splits the viewport into four windows.
;; It then takes one of the four windows, and splits that
;; window horizontally in half.
;; Create a new viewport and make it active
(setq newViewport (vla-Add (vla-get-Viewports doc) "TESTVIEWPORT"))
(vla-put-ActiveViewport doc newViewport)
;; Split the viewport in four windows
(vla-Split newViewport acViewport4)
;; Make the newly split viewport active
;; Note that current drawing layout will show four windows.
;; However, only one of the windows will be active.
;; The following code sets the lower-left corner window
;; to be the active window and then splits that
;; window into two horizontal windows.
(vlax-for entry (vla-get-Viewports doc)
(if (= (vla-get-Name entry) "TESTVIEWPORT")
(progn
(setq lowerLeft (vlax-variant-value (vla-get-LowerLeftCorner entry)))
(if (and (= (vlax-safearray-get-element lowerLeft 0) 0)
(= (vlax-safearray-get-element lowerLeft 1) 0))
(setq newViewport entry)
(vla-Split newViewport acViewport2Horizontal)
GMT+8, 2026-11-13 13:33
