Replace 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 785| 评论: 0|原作者: admin|来自: AutoCAD
将字典中的项目替换为给定项目。
object.Replace Name, NewObject
类型: 字典
此方法应用到的对象。
名字
访问:仅输入
类型:字符串
要替换的对象的名称(关键字)。
新对象
访问:仅输入
类型:对象
新对象。
返回值 (RetVal)
无返回值。
例如,以下字典中的“FirstKeyword”:
  • 我的词典
  • 关键字对象
  • FirstKeyword 对象 1
  • SecondKeyword 对象2
附加了一个新对象“NewObject”:
  • 我的词典
  • 关键字对象
  • FirstKeyword NewObject
  • SecondKeyword 对象2
Sub Example_Replace()
    ' This example creates a dictionary and adds
    ' a custom object to that dictionary. It then
    ' replaces the object in the dictionary.
    Dim dictObj As AcadDictionary
    Set dictObj = ThisDrawing.Dictionaries.Add("TEST_DICTIONARY")
    ' Load the ObjectARX application that defines the custom object.
    ' Note: The application listed here does not exist and
    ' will cause an error when run. Change the application name
    ' to the path and name of your ObjectARX application.
    ThisDrawing.Application.LoadArx "MyARXApp.dll"
    ' Create the custom object in the dictionary
    Dim keyName As String
    Dim className As String
    Dim customObj As AcadObject
    keyName = "OBJ1"
    className = "CAsdkDictObject"
    Set customObj = dictObj.AddObject(keyName, className)
    ' Replace the object from the dictionary with a different object
    Dim newCustomObject As AcadObject
    dictObj.Replace keyName, newCustomObject
(defun c:Example_Replace()
    ;; This example creates a dictionary and adds
    ;; a custom object to that dictionary. It then
    ;; replaces the object in the dictionary.
    (setq dictObj (vla-Add dictionaries "TEST_DICTIONARY"))
    ;; Load the ObjectARX application that defines the custom object.
    ;; Note: The application listed here does not exist and
    ;; will cause an error when run. Change the application name
    ;; to the path and name of your ObjectARX application.
    (vla-LoadArx acadObj "MyARXApp.dll")
    ;; Create the custom object in the dictionary
    (setq keyName "OBJ1")
    (setq className "CAsdkDictObject")
    (setq customObj (vla-AddObject dictObj keyName className))
    ;; Replace the object from the dictionary with a different object
    (setq newCustomObject (vlax-make-variant))
    (vlax-variant-type newCustomObject vlax-vbObject)
    (vla-Replace dictObj keyName newCustomObject)
GMT+8, 2026-11-13 13:38
