Offset 方法 (ActiveX)
在与现有对象的指定偏移距离处创建新对象。 支持的平台:仅限 Windows 签名VBA: RetVal = object.Offset(Distance) 返回值 (RetVal)类型:变体(对象数组) 由偏移量生成的新创建对象的数组。 言论对于许多曲线,此操作的结果将是一条新曲线(可能与原始曲线的类型不同)。例如,偏移椭圆将导致样条曲线,因为结果不符合椭圆方程。在某些情况下,偏移结果可能需要是几条曲线。 ![]() 原始对象和偏移量为红色的对象。 例子VBA: Sub Example_Offset()
' This example creates a lightweight polyline
' and then offsets the polyline.
' Create the polyline
Dim points(0 To 11) As Double
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 1
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = True
ZoomAll
MsgBox "Offset the polyline by 0.25.", , "Offset Example"
' Offset the polyline
Dim offsetObj As Variant
offsetObj = plineObj.offset(0.25)
ZoomAll
MsgBox "Offset completed.", , "Offset Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Offset()
;; This example creates a lightweight polyline
;; and then offsets the polyline.
;; Create the polyline
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 11)))
(vlax-safearray-fill points '(1 1
1 2
2 2
3 2
4 4
4 1
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-put-Closed plineObj :vlax-true)
(vla-ZoomAll acadObj)
(alert "Offset the polyline by 0.25.")
;; Offset the polyline
(setq offsetObj (vla-Offset plineObj 0.25))
(alert "Offset completed.")
GMT+8, 2026-11-12 13:02
