LoadARX 方法 (ActiveX)
加载指定的 ObjectARX 应用程序。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_LoadARX()
' This example loads an ObjectARX application.
' Note: The application listed here does not exist and
' will cause an error when run. Change the application name
' to the path and name of your ObjectARX application.
ThisDrawing.Application.LoadArx "MyARXApp.arx"
可视化 LISP: (vl-load-com)
(defun c:Example_LoadARX()
;; This example loads an ObjectARX application.
;; Note: The application listed here does not exist and
;; will cause an error when run. Change the application name
;; to the path and name of your ObjectARX application.
(vla-LoadArx acadObj "MyARXApp.arx")
GMT+8, 2026-11-14 14:44
