Item 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 1042| 评论: 0|原作者: admin|来自: AutoCAD
Item 方法 (ActiveX)
获取集合、组或选择集中给定索引处的成员对象。
RetVal = object.Item(Index)
类型:所有集合、组、SelectionSet
此方法应用到的对象。
指数
访问:仅输入
类型:变体
要查询的成员项在集合中的索引位置。
索引必须是整数或字符串。如果是整数,则索引必须介于 0 和 N-1 之间,其中 N 是集合或选择集中的对象数。
返回值 (RetVal)
类型:对象
集合或选择集中给定索引位置的对象。
此方法支持基于字符串的迭代。例如,如果使用以下语句创建名为 BLOCK1 的块:
Set block1 = Blocks.Add("BLOCK1")
您可以通过以下语句引用对象:
Set whichblock = Blocks.Item("BLOCK1")
注意:与集合一起使用时,Item 方法区分大小写;对于其他集合,它不区分大小写。SelectionSets
字典:此方法的返回值类型为 。这允许您从字典集合中检索不属于 类型的命名对象。IAcadObjectDictionary
Sub Example_Item()
    ' This example shows two uses of the Item method.
    ' The first uses Item with an index counter to return an item in a collection.
    ' The second uses Item with a string to return an item in a collection.
    ' Iterate thru the model space collection,
    ' get all the items in the collection
    ' and store them in an array called newObjs
    Dim count As Integer
    count = ThisDrawing.ModelSpace.count
    ReDim newObjs(count) As AcadEntity
    Dim index As Integer
    For index = 0 To count - 1
        Set newObjs(index) = ThisDrawing.ModelSpace.Item(index)
    Next
    ' Get a particular item, in this case a layer, based on name "0"
    Dim layerObj As AcadLayer
    Set layerObj = ThisDrawing.Layers.Item("0")
(defun c:Example_Item()
    ;; This example shows two uses of the Item method.
    ;; The first uses Item with an index counter to return an item in a collection.
    ;; The second uses Item with a string to return an item in a collection.
    ;; Iterate thru the model space collection,
    ;; get all the items in the collection
    ;; and store them in an array called newObjs
    (setq count (vla-get-Count (vla-get-ModelSpace doc))
          index 0)
    (setq newObjs (vlax-make-safearray vlax-vbObject (cons 0 count)))
    (while (>= (1- count) index)
        (vlax-safearray-put-element newObjs index (vla-Item (vla-get-ModelSpace doc) index))
        (setq index (1+ index))
    ;; Get a particular item, in this case a layer, based on name "0"
    (setq layerObj (vla-Item (vla-get-Layers doc) "0"))
GMT+8, 2026-11-12 12:24
