GetProjectFilePath 方法 (ActiveX)
获取 AutoCAD 在其中查找外部参照文件的目录。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetProjectFilePath(ProjectName)
返回值 (RetVal)类型:字符串 AutoCAD 在其中查找外部参考文件的目录。 言论没有其他评论。 例子VBA: Sub Example_GetProjectFilePath()
' This example finds the current project file information.
Set preferences = ThisDrawing.Application.preferences
' Get the current project file information
Dim currProjPath As String
Dim currProjName As Variant
currProjName = ThisDrawing.GetVariable("PROJECTNAME")
If currProjName <> "" Then
currProjPath = preferences.Files.GetProjectFilePath(currProjName)
End If
If currProjPath = "" Then
MsgBox "There is no current project file or path. ", , "GetProjectFilePath Example"
Else
MsgBox "The current project file path is: " & currProjPath, , "GetProjectFilePath Example"
End If
可视化 LISP: (vl-load-com)
(defun c:Example_GetProjectFilePath()
;; This example finds the current project file information.
;; Get the current project file information
(setq currProjName (vlax-variant-value (vla-GetVariable doc "PROJECTNAME")))
(if (/= currProjName "")
(progn
(setq currProjPath (vla-GetProjectFilePath (vla-get-Files preferences) currProjName))
(alert (strcat "The current project file path is: " currProjPath))
(alert "There is no current project file or path.")
GMT+8, 2026-11-15 15:07
