GetFitPoint 方法 (ActiveX)
获取样条曲线在给定索引处的拟合点。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetFitPoint(Index)
返回值 (RetVal)类型:变体(双打的三元素阵列) 拟合点在给定索引位置的 3D WCS 坐标。 言论没有其他评论。 例子VBA: Sub Example_GetFitPoint()
' This example creates a spline object in model space.
' It then finds the coordinates of the fit points.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
' Display the coordinates of the fit points
Dim fitPoint As Variant
Dim index As Integer
For index = 0 To splineObj.NumberOfFitPoints - 1
fitPoint = splineObj.GetFitPoint(index)
MsgBox "Fit point " & index + 1 & " is at " & fitPoint(0) & ", " & fitPoint(1) & ", " & fitPoint(2), , "GetFitPoint Example"
Next
可视化 LISP: (vl-load-com)
(defun c:Example_GetFitPoint()
;; This example creates a spline object in model space.
;; It then finds the coordinates of the fit points.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
;; Display the coordinates of the fit points
(setq index 0)
(while (>= (1- (vla-get-NumberOfFitPoints splineObj)) 0)
(setq fitPoint (vlax-safearray->list (vlax-variant-value (vla-GetFitPoint splineObj index))))
(alert (strcat "Fit point " (itoa (1+ index)) " is at " (rtos (nth 0 fitPoint) 2) ", " (rtos (nth 1 fitPoint) 2) ", " (rtos (nth 2 fitPoint) 2)))
(setq index (1+ index))
GMT+8, 2026-10-23 00:12
