GetBackgroundColorNone 方法 (ActiveX)
返回指定指定行类型没有背景色的值。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetBackgroundColorNone(rowType)
返回值 (RetVal)类型:布尔
言论没有其他评论。 例子VBA: Sub Example_GetBackgroundColorNone()
' the style name and other attributes.
Dim dictObj As AcadDictionary
' Get the current TableStyle object
Dim tableStyle As AcadTableStyle
Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE"))
Dim colCurrent As AcadAcCmColor, colRowCurrent As AcadAcCmColor, colNoneCurrent As Boolean
Set colCurrent = tableStyle.GetBackgroundColor(AcRowType.acDataRow + AcRowType.acTitleRow)
Set colRowCurrent = tableStyle.GetColor(acDataRow)
colNoneCurrent = tableStyle.GetBackgroundColorNone(AcRowType.acHeaderRow)
MsgBox "Table colors " & vbLf & _
"Background ACI value = " & colCurrent.ColorIndex & vbLf & _
"Row Text ACI value = " & colRowCurrent.ColorIndex & vbLf & _
"Background None = " & colNoneCurrent
Dim col As AcadAcCmColor
Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
col.SetRGB 0, 0, 255
tableStyle.SetBackgroundColor AcRowType.acTitleRow, col
col.SetRGB 255, 0, 0
tableStyle.SetColor AcRowType.acDataRow, col
If colNoneCurrent = False Then
tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, True
Else
tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, False
End If
Dim colNew As AcadAcCmColor, colRowNew As AcadAcCmColor, colNoneNew As Boolean
Set colNew = tableStyle.GetBackgroundColor(AcRowType.acTitleRow)
Set colRowNew = tableStyle.GetColor(acDataRow)
colNoneNew = tableStyle.GetBackgroundColorNone(acHeaderRow)
"Background ACI value = " & colNew.ColorIndex & vbLf & _
"Row Text ACI value = " & colRowNew.ColorIndex & vbLf & _
"Background None = " & colNoneNew
tableStyle.SetBackgroundColor AcRowType.acTitleRow, colCurrent
tableStyle.SetColor AcRowType.acDataRow, colRowCurrent
tableStyle.SetBackgroundColorNone AcRowType.acHeaderRow, colNoneCurrent
MsgBox "Reset the table style back to its original values."
可视化 LISP: (vl-load-com)
(defun c:Example_GetBackgroundColorNone()
;; the style name and other attributes.
(setq dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Get the current TableStyle object
(setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE")))
(setq colCurrent (vla-GetBackgroundColor tableStyle (+ acDataRow acTitleRow)))
(setq colRowCurrent (vla-GetColor tableStyle acDataRow))
(setq colNoneCurrent (vla-GetBackgroundColorNone tableStyle acHeaderRow))
(alert (strcat "Table colors \n"
"Background ACI value = " (itoa (vla-get-ColorIndex colCurrent)) "\n"
"Row Text ACI value = " (itoa (vla-get-ColorIndex colRowCurrent)) "\n"
"Background None = " (if (= colNoneCurrent :vlax-true) "True" "False")))
(setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
(vla-SetRGB col 0 0 255)
(vla-SetBackgroundColor tableStyle acTitleRow col)
(vla-SetRGB col 255 0 0)
(vla-SetColor tableStyle acDataRow col)
(vla-SetBackgroundColorNone tableStyle acHeaderRow (if (= colNoneCurrent :vlax-true) :vlax-false :vlax-true))
(setq colNew (vla-GetBackgroundColor tableStyle acTitleRow))
(setq colRowNew (vla-GetColor tableStyle acDataRow))
(setq colNoneNew (vla-GetBackgroundColorNone tableStyle acHeaderRow))
"Background ACI value = " (itoa (vla-get-ColorIndex colNew)) "\n"
"Row Text ACI value = " (itoa (vla-get-ColorIndex colRowNew)) "\n"
"Background None = " (if (= colNoneNew :vlax-true) "True" "False")))
(vla-SetBackgroundColor tableStyle acTitleRow colCurrent)
(vla-SetColor tableStyle acDataRow colRowCurrent)
(vla-SetBackgroundColorNone tableStyle acHeaderRow colNoneCurrent)
(alert "Reset the table style back to its original values.")
(vlax-release-object col)
GMT+8, 2026-11-13 13:27
