ElevateOrder 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 884| 评论: 0|原作者: admin|来自: AutoCAD
将样条曲线的顺序提升到给定顺序。
object.ElevateOrder Order
类型:样条曲线
此方法应用到的对象。
次序
访问:仅输入
类型:整数
大于当前订单的正值。最大订单为 26。
返回值 (RetVal)
无返回值。
样条曲线的阶数等于样条曲线的阶数加一 (+1)。可以使用属性查询样条的度数。Degree
输入大于当前值的值会均匀地增加样条曲线上的控制点数,以实现更局部的控制。样条阶一旦提升,就不能减少。
当样条曲线被抬高时,该样条曲线将从插值(拟合)样条转换为控制点样条曲线。这意味着在高程之后,样条不再具有拟合切线,并且样条的 和 属性不再可用。编辑控制点样条曲线的唯一方法是通过属性或 or 方法。StartTangentEndTangentControlPointsSetControlPointGetControlPoint
Sub Example_ElevateOrder()
    ' This example creates a spline object in model space.
    ' It then elevates the order of the spline.
    ' Create the spline
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
    MsgBox "The current order of the spline is " & splineObj.Degree + 1, , "ElevateOrder Example"
    ' Elevate the order of the spline
    splineObj.ElevateOrder (splineObj.Degree + 10)
    ThisDrawing.Regen True
    MsgBox "The order of the spline has been raised to " & splineObj.Degree + 1, , "ElevateOrder Example"
(defun c:Example_ElevateOrder()
    ;; This example creates a spline object in model space.
    ;; It then elevates the order of the spline.
    ;; Create the spline
    (setq startTan (vlax-3d-point 0.5 0.5 0)
          endTan (vlax-3d-point 0.5 0.5 0)
          fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill fitPoints '(1 1 0
                                     5 5 0
                                     10 0 0
    (setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
    (vla-ZoomAll acadObj)
    (alert (strcat "The current order of the spline is " (itoa (1+ (vla-get-Degree splineObj)))))
    ;; Elevate the order of the spline
    (vla-ElevateOrder splineObj (+ (vla-get-Degree splineObj) 10))
    (vla-Regen doc :vlax-true)
    (alert (strcat "The order of the spline has been raised to " (itoa (1+ (vla-get-Degree splineObj)))))
GMT+8, 2026-11-13 13:35
