DistanceToReal 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 841| 评论: 0|原作者: admin|来自: AutoCAD
将字符串的距离转换为实数(双精度)值。
RetVal = DistanceToReal(Distance, Unit)
类型: 实用程序
此方法应用到的对象。
距离
访问:仅输入
类型:字符串
以字符串值表示的距离。
单位
访问:仅输入
类型:枚举AcUnits
要将字符串转换为的单位。
  • acDefaultUnits
  • acScientific
  • acDecimal
  • acEngineering
  • acArchitectural
  • acFractional
返回值 (RetVal)
类型:双
以实数表示的距离。
Sub Example_DistanceToReal()
    ' This example passes several different distances in
    ' different units to be converted to real values.
    Dim distAsString As String
    Dim unit As Long
    Dim distAsReal As Double
    ' Convert the distance to a real in scientific units
    unit = acScientific
    distAsString = "1.75E+01"
    distAsReal = ThisDrawing.Utility.DistanceToReal(distAsString, unit)
    MsgBox "1.75E+01 converts to " & distAsReal & " in scientific units.", , "DistanceToReal Example"
    ' Convert the distance to a real in decimal units
    unit = acDecimal
    distAsString = "17.5"
    MsgBox "1.75 converts to " & distAsReal & " in decimal units.", , "DistanceToReal Example"
    ' Convert the distance to a real in engineering units
    unit = acEngineering
    distAsString = "1'-5.50"""
    MsgBox "1'-5.50"" converts to " & distAsReal & " in engineering units.", , "DistanceToReal Example"
    ' Convert the distance to a real in architectural units
    unit = acArchitectural
    distAsString = "1'-5 1/2"""
    MsgBox "1'-5 1/2"" converts to " & distAsReal & " in architectural units.", , "DistanceToReal Example"
    ' Convert the distance to a real in fractional units
    unit = acFractional
    distAsString = "17 1/2"
    MsgBox "1'-5 1/2"" converts to " & distAsReal & " in fractional units.", , "DistanceToReal Example"
(defun c:Example_DistanceToReal()
    ;; This example passes several different distances in
    ;; different units to be converted to real values.
    ;; Convert the distance to a real in scientific units
    (setq unit acScientific
          distAsString "1.75E+01"
          distAsReal (vla-DistanceToReal (vla-get-Utility doc) distAsString unit))
    (alert (strcat "1.75E+01 converts to " (rtos distAsReal 2) " in scientific units."))
    ;; Convert the distance to a real in decimal units
    (setq unit acDecimal
          distAsString "17.5"
    (alert (strcat "17.5 converts to " (rtos distAsReal 2) " in decimal units."))
    ;; Convert the distance to a real in engineering units
    (setq unit acEngineering
          distAsString "1'-5.50\""
    (alert (strcat "1'-5.50\" converts to " (rtos distAsReal 2) " in engineering units."))
    ;; Convert the distance to a real in architectural units
    (setq unit acArchitectural
          distAsString "1'-5 1/2\""
    (alert (strcat "1'-5 1/2\" converts to " (rtos distAsReal 2) " in architectural units."))
    ;; Convert the distance to a real in fractional units
    (setq unit acFractional
          distAsString "17 1/2"
    (alert (strcat "17 1/2 converts to " (rtos distAsReal 2) " in fractional units."))
GMT+8, 2026-11-13 13:47
