Detach 方法 (ActiveX)
从绘图中分离外部参照 (外部参照)。 支持的平台:仅限 Windows 返回值 (RetVal)无返回值。 言论分离外部参照会从当前图形中移除外部参照。将擦除外部参照的所有副本,并删除外部参照定义。所有与外部参照相关的符号表信息(如图层和线型)都将从当前图形中删除。 不能分离包含其他外部参照的外部参照。 例子VBA: Sub Example_Detach()
On Error GoTo ERRORHANDLER
' Define external reference to be inserted
Dim xrefHome As AcadBlock
Dim xrefInserted As AcadExternalReference
Dim insertionPnt(0 To 2) As Double
Dim PathName As String
insertionPnt(0) = 1
insertionPnt(1) = 1
insertionPnt(2) = 0
PathName = "c:/AutoCAD/sample/City map.dwg"
' Add the external reference
Set xrefInserted = ThisDrawing.ModelSpace. _
AttachExternalReference(PathName, "XREF_IMAGE", _
insertionPnt, 1, 1, 1, 0, False)
ZoomAll
MsgBox "The external reference is attached."
' Detach the external reference definition
Dim name As String
name = xrefInserted.name
ThisDrawing.Blocks.Item(name).Detach
MsgBox "The external reference is detached."
Exit Sub
ERRORHANDLER:
MsgBox Err.Description
可视化 LISP: (vl-load-com)
(defun c:Example_Detach()
;; Define external reference to be inserted
(setq insertionPnt (vlax-3d-point 1 1 0)
pathName (findfile ".\\Sample\\Sheet Sets\\Architectural\\Res\\STAIR1.dwg"))
;; Add the external reference
(setq xrefInserted (vla-AttachExternalReference modelSpace pathName "XREF_IMAGE" insertionPnt 1 1 1 0 :vlax-false))
(vla-ZoomAll acadObj)
(alert "The external reference is attached.")
;; Detach the external reference definition
(setq name (vla-get-Name xrefInserted))
(vla-Detach (vla-Item (vla-get-Blocks doc) name))
(alert "The external reference is detached.")
GMT+8, 2026-11-13 13:27
