CreateContent 方法 (ActiveX)
在单元格中创建新内容。 支持的平台:仅限 Windows 签名VBA: RetVal = object.CreateContent(nRow, nCol, nIndex)
返回值 (RetVal)类型:长 已创建内容的 ID。 言论没有其他评论。 例子VBA: Sub Example_ContentChange()
' This example adds a table in model space
' and manipulates its contents
' Note: One content is created for each cell by default;
' this function need to be called only to create additional contents.
Dim MyModelSpace As AcadModelSpace
Set MyModelSpace = ThisDrawing.modelSpace
Dim pt(2) As Double
Dim MyTable As IAcadTable
Dim sID As Long
Dim newSID As Long
Dim row As Long
Dim col As Long
' Creates arbitrary cell points to check
row = 2
col = 2
' Creates the table with an arbitrary number of cells
Set MyTable = MyModelSpace.AddTable(pt, 5, 5, 10, 30)
If MyTable.IsEmpty(row, col) Then
If MyTable.IsContentEditable(row, col) Then
MsgBox "There is no content in the cell, but it is editable"
End If
End If
' Create some content in an arbitrary cell
sID = MyTable.CreateContent(row, col, 8)
MsgBox "The content ID is " & sID
' Move the content to another index
MyTable.MoveContent row, col, sID, 4
' Check that the content has been deleted
MyTable.DeleteContent row, col
End If
End If
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_ContentChange()
;; This example adds a table in model space
;; and manipulates its contents
;; Note: One content is created for each cell by default;
;; this function need to be called only to create additional contents.
(setq pt (vlax-3d-point 0 0 0))
;; Creates arbitrary cell points to check
(setq row 2
col 2)
;; Creates the table with an arbitrary number of cells
(setq MyTable (vla-AddTable modelSpace pt 5 5 10 30))
(vla-SetTextHeight MyTable (+ acDataRow acHeaderRow acTitleRow) 1)
(vla-Regen doc :vlax-true)
(vla-ZoomExtents acadObj)
(if (= (vla-IsEmpty MyTable row col) :vlax-true)
(if (= (vla-IsContentEditable MyTable row col) :vlax-true)
(alert "There is no content in the cell, but it is editable")
;; Create some content in an arbitrary cell
(setq sID1 (vla-CreateContent MyTable row col 0))
(setq sID2 (vla-CreateContent MyTable row col 1))
(vla-SetTextString MyTable row col sID1 "Value1")
(vla-SetTextString MyTable row col sID2 "Value2")
(alert (strcat "The content IDs are "
"\nValue1: " (itoa sID1)
"\nValue2: " (itoa sID2)))
;; Move the content to another index
(vla-MoveContent MyTable row col sID2 sID1)
(alert "Content order changed")
; Check that the content has been deleted
(vla-DeleteContent MyTable row col)
GMT+8, 2026-11-12 12:23
