CopyProfile 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 654| 评论: 0|原作者: admin|来自: AutoCAD
复制指定的配置文件。
object.CopyProfile oldProfileName, newProfileName
类型:PreferencesProfiles
此方法应用到的对象。
oldProfileName
访问:仅输入
类型:字符串
要复制的配置文件的名称。
newProfileName (新配置文件名称)
访问:仅输入
类型:字符串
要创建的新配置文件的名称。
返回值 (RetVal)
无返回值。
Sub Example_CopyProfile()
    ' This example copies an existing profile.
    ' You can see the new profile under Options/Profiles
    ' *Note: This example relies on the default profile "<<Unnamed Profile>>".
    ' If this profile has already been renamed or removed, be sure to change the
    ' name of the SourceProfile to one that currently exists.
    Dim ACADPref As AcadPreferencesProfiles
    Dim SourceProfile As String, DestinationProfile As String
    ' Use the PreferencesProfiles object
    Set ACADPref = ThisDrawing.Application.Preferences.Profiles
    ' Copy the default profile
    On Error GoTo ERRORTRAP
    SourceProfile = "<<Unnamed Profile>>"
    DestinationProfile = "NEW_PROFILE"
    ACADPref.CopyProfile SourceProfile, DestinationProfile
    MsgBox "We have just copied the existing profile " & SourceProfile & " to " & DestinationProfile
    Exit Sub
ERRORTRAP:
    If Err.Description <> "" Then
        MsgBox "The default profile '" & SourceProfile & "' cannot be found, please use a different source profile."
    End If
(defun c:Example_CopyProfile()
    ;; This example copies an existing profile.
    ;; You can see the new profile under Options/Profiles
    ;; *Note: This example relies on the default profile "<<Unnamed Profile>>".
    ;; If this profile has already been renamed or removed, be sure to change the
    ;; name of the SourceProfile to one that currently exists.
    ;; Use the PreferencesProfiles object
    (setq ACADPref (vla-get-Profiles preferences))
    (setq SourceProfile "<<Unnamed Profile>>"
          DestinationProfile "NEW_PROFILE")
    (vla-CopyProfile ACADPref SourceProfile DestinationProfile)
    (alert (strcat "We have just copied the existing profile " SourceProfile " to " DestinationProfile))
GMT+8, 2026-11-14 18:28
