ClipBoundary 方法 (ActiveX)
指定光栅图像或参考底图的剪切边界。 支持的平台:仅限 Windows 签名VBA: object.ClipBoundary PointsArray
返回值 (RetVal)无返回值。 言论您可以通过裁剪对象来定义图像或参考底图对象的区域,以便进行显示和打印。同一对象的多个实例可以具有不同的边界。 剪裁边界必须是闭合的 2D 多边形或矩形,其顶点被约束为位于图像或参考底图的边界内。 要裁剪图像或参考底图,对象的边界必须可见。使用该属性打开或关闭剪裁边界。ClippingEnabled 例子VBA: Sub Example_ClipBoundary()
' This example adds a raster image in model space.
' It then clips the image based on a clip boundary.
' This example uses the "2d Projected Polylines.jpg" found in the Sample
' directory. If you do not have the image, or if it is located
' in a different directory, insert a valid path and name for the
' imageName variable below.
Dim scalefactor As Double
Dim rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
insertionPoint(0) = 5#: insertionPoint(1) = 5#: insertionPoint(2) = 0#
scalefactor = 2#
rotationAngle = 0
On Error Resume Next
' Creates a raster image in model space
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
If Err.Description = "Filer error" Then
MsgBox imageName & " could not be found."
Exit Sub
End If
ZoomAll
MsgBox "Clip the image?", , "ClipBoundary Example"
' Establish the clip boundary with an array of points
Dim clipPoints(0 To 9) As Double
clipPoints(0) = 6: clipPoints(1) = 6.75
clipPoints(2) = 7: clipPoints(3) = 6
clipPoints(4) = 6: clipPoints(5) = 5
clipPoints(6) = 5: clipPoints(7) = 6
clipPoints(8) = 6: clipPoints(9) = 6.75
' Clip the image
rasterObj.clipBoundary clipPoints
' Enable the display of the clip
rasterObj.ClippingEnabled = True
ThisDrawing.Regen acActiveViewport
MsgBox "The image has been clipped.", , "ClipBoundary Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ClipBoundary()
;; This example adds a raster image in model space.
;; It then clips the image based on a clip boundary.
;; This example uses the "2d Projected Polylines.jpg" found in the Sample
;; directory. If you do not have the image, or if it is located
;; in a different directory, insert a valid path and name for the
;; imageName variable below.
(setq insertionPoint (vlax-3d-point 5 5 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 2
rotationAngle 0)
(if (/= (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") nil)
(progn
;; Creates a raster image in model space
(setq rasterObj (vla-AddRaster modelSpace (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") insertionPoint scalefactor rotationAngle))
(vla-ZoomAll acadObj)
(alert "Clip the image?")
;; Establish the clip boundary with an array of points
(setq clipPoints (vlax-make-safearray vlax-vbDouble '(0 . 9)))
(vlax-safearray-fill clipPoints '(6 6.75
7 6
6 5
5 6
6 6.75
;; Clip the image
(vla-ClipBoundary rasterObj clipPoints)
;; Enable the display of the clip
(vla-put-ClippingEnabled rasterObj :vlax-true)
(vla-Regen doc acActiveViewport)
(alert "The image has been clipped.")
(alert (strcat imageName " could not be found."))
GMT+8, 2026-11-12 12:39
