AppendItems 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 1015| 评论: 0|原作者: admin|来自: AutoCAD
将一个或多个实体追加到指定的组。
object.AppendItems Objects
类型: 组
此方法应用到的对象。
访问:仅输入
类型:Variant(任何图形对象的数组)
要追加的对象数组。数组可以由任何图形对象组成。
返回值 (RetVal)
无返回值。
若要查询组中的项,请使用该方法。Item
若要从组中删除单个项目,请使用以下方法。RemoveItems
Sub Example_AppendItems()
    ' This example creates a group and several objects.
    ' It then appends the objects to the group.
    ' Create the new group
    Dim groupObj As AcadGroup
    Set groupObj = ThisDrawing.Groups.Add("TEST_GROUP")
    ' Create a Ray object in model space
    Dim rayObj As AcadRay
    Dim basePoint(0 To 2) As Double
    Dim SecondPoint(0 To 2) As Double
    basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
    SecondPoint(0) = 1#: SecondPoint(1) = 3#: SecondPoint(2) = 0#
    Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, SecondPoint)
    ' Create a polyline object in model space
    Dim points(0 To 5) As Double
    points(0) = 3: points(1) = 7
    points(2) = 9: points(3) = 2
    points(4) = 3: points(5) = 5
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    plineObj.Closed = True
    ' Create a line object in model space
    Dim lineObj As AcadLine
    startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
    endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
    ' Create a circle object in model space
    Dim circObj As AcadCircle
    Dim centerPt(0 To 2) As Double
    Dim radius As Double
    centerPt(0) = 20: centerPt(1) = 30: centerPt(2) = 0
    radius = 3
    Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, radius)
    ' Create an ellipse object in model space
    Dim ellObj As AcadEllipse
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ZoomAll
    ' Iterate through the model space collection.
    ' Collect the objects found into an array of objects
    ' to be added to the group.
    ReDim appendObjs(0 To ThisDrawing.ModelSpace.count - 1) As AcadEntity
    Dim I As Integer
    For I = 0 To ThisDrawing.ModelSpace.count - 1
        Set appendObjs(I) = ThisDrawing.ModelSpace.Item(I)
    Next
    ' Add the array of objects to the group
    groupObj.AppendItems appendObjs
    ThisDrawing.Regen acActiveViewport
(defun c:Example_AppendItems()
    ;; This example creates a group and several objects.
    ;; It then appends the objects to the group.
    ;; Create the new group
    (setq groupObj (vla-Add (vla-get-Groups doc) "TEST_GROUP"))
    ;; Create a Ray object in model space
    (setq basePoint (vlax-3d-point 3 3 0)
          secondPoint (vlax-3d-point 1 3 0))
    (setq rayObj (vla-AddRay modelSpace basePoint SecondPoint))
    ;; Create a polyline object in model space
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill points '(3 7
                                  9 2
                                  3 5
    (setq plineObj (vla-AddLightWeightPolyline modelSpace points))
    (vla-put-Closed plineObj :vlax-true)
    ;; Create a line object in model space
    (setq startPoint (vlax-3d-point 0 0 0)
          endPoint (vlax-3d-point 2 2 0))
    ;; Create a circle object in model space
    (setq centerPt (vlax-3d-point 20 30 0)
          radius 3)
    (setq circObj (vla-AddCircle modelSpace centerPt radius))
    ;; Create an ellipse object in model space
    (setq center (vlax-3d-point 5 5 0)
          majAxis (vlax-3d-point 10 20 0)
          radRatio 0.3)
    (setq ellObj (vla-AddEllipse modelSpace center majAxis radRatio))
    (vla-ZoomAll acadObj)
    ;; Iterate through the model space collection.
    ;; Collect the objects found into an array of objects
    ;; to be added to the group.
    (setq I 0
	         totalObjs (vla-get-Count modelSpace))
    (setq appendObjs (vlax-make-safearray vlax-vbObject (cons 0 (- totalObjs 1))))
    (while (>= (- totalObjs 1) I)
        (vlax-safearray-put-element appendObjs I (vla-Item modelSpace I))
        (setq I (1+ I))
    ;; Add the array of objects to the group
    (vla-AppendItems groupObj appendObjs)
    (vla-Regen doc acActiveViewport)
GMT+8, 2026-11-12 12:23
