AddVertex 方法 (ActiveX)
将顶点添加到轻量级折线或截面。 支持的平台:仅限 Windows 签名VBA: object.AddVertex Index, Point
返回值 (RetVal)无返回值。 言论LWPolyline:顶点指定新线段的端点。要将弧段添加到轻量级折线,请先创建线段,然后将“凸起”添加到要成为弧的单个线段。若要向区段添加凸起值,请使用该方法。SetBulge 截面:顶点指定截面线上的一个点。 可以使用该方法将坐标转换为 OCS 或从 OCS 转换坐标。TranslateCoordinates 例子VBA: Sub Example_AddVertex()
' This example creates a lightweight polyline in model space.
' It then adds a vertex to the polyline.
Dim points(0 To 9) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
' Create a lightweight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
ZoomAll
MsgBox "Add a vertex to the end of the polyline.", , "AddVertex Example"
' Define the new vertex
Dim newVertex(0 To 1) As Double
newVertex(0) = 4: newVertex(1) = 1
' Add the vertex to the polyline
plineObj.AddVertex 5, newVertex
plineObj.Update
MsgBox "Vertex added.", , "AddVertex Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AddVertex()
;; This example creates a lightweight polyline in model space.
;; It then adds a vertex to the polyline.
;; Define the 2D polyline points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 9)))
(vlax-safearray-fill points '(1 1
1 2
2 2
3 2
4 4
;; Create a lightweight Polyline object in model space
(setq plineObj (vla-AddLightWeightPolyline modelSpace points))
(vla-ZoomAll acadObj)
(alert "Add a vertex to the end of the polyline.")
;; Define the new vertex
(setq newVertex (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-fill newVertex '(4 1))
;; Add the vertex to the polyline
(vla-AddVertex plineObj 5 newVertex)
(vla-Update plineObj)
(alert "Vertex added.")
GMT+8, 2026-11-13 14:03
