AddTorus 方法 (ActiveX)
在给定位置创建圆环。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddTorus(Center, TorusRadius, TubeRadius) 言论没有其他评论。 例子VBA: Sub Example_AddTorus()
' This example creates a torus in model space.
Dim torusObj As Acad3DSolid
Dim torusRadius As Double
Dim tubeRadius As Double
' Define the torus
centerPoint(0) = 5: centerPoint(1) = 5: centerPoint(2) = 0
torusRadius = 15
tubeRadius = 5
' Create the torus
Set torusObj = ThisDrawing.ModelSpace.AddTorus(centerPoint, torusRadius, tubeRadius)
' Change the viewing direction of the viewport
Dim NewDirection(0 To 2) As Double
NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
ThisDrawing.ActiveViewport.direction = NewDirection
ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_AddTorus()
;; This example creates a torus in model space.
;; Define the torus
(setq centerPoint (vlax-3d-point 5 5 0)
torusRadius 15
tubeRadius 5)
;; Create the torus
(setq torusObj (vla-AddTorus modelSpace centerPoint torusRadius tubeRadius))
;; Change the viewing direction of the viewport
(setq NewDirection (vlax-3d-point -1 -1 1))
(setq activeViewport (vla-get-ActiveViewport doc))
(vla-put-Direction activeViewport NewDirection)
(vla-put-ActiveViewport doc activeViewport)
(vla-ZoomAll acadObj)
GMT+8, 2026-11-15 16:08
