AddPViewport 方法 (ActiveX)
添加给定中心、高度和宽度的纸张空间视口。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddPViewport(Center, Width, Height)
言论没有其他评论。 例子VBA: Sub Example_AddPViewport()
' This example creates a new paper space viewport
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
' Define the paper space viewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
' Change from model space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Create the paper space viewport
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
可视化 LISP: (vl-load-com)
(defun c:Example_AddPViewport()
;; This example creates a new paper space viewport
;; Define the paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
;; Change from model space to paper space
(vla-put-ActiveSpace doc acPaperSpace)
;; Create the paper space viewport
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
;; Turn the viewport on, by default it is off
(vla-Display pviewportObj :vlax-true)
GMT+8, 2026-11-14 18:20
