AddMLine 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 862| 评论: 0|原作者: admin|来自: AutoCAD
创建通过点数组的多条线。
RetVal = object.AddMLine(VertexList)
类型:块、模型空间、纸空间
此方法应用到的对象。
顶点列表
访问:仅输入
类型:变体(双打数组)
指定多线顶点的 3D WCS 坐标数组。
返回值 (RetVal)
类型: MLine
新创建的对象。MLine
Sub Example_AddMLine()
   ' This example adds an Mline in model space
    Dim mLineObj As AcadMLine
    Dim vertexList(0 To 17) As Double
    ' Define data for new object
    vertexList(0) = 4: vertexList(1) = 7: vertexList(2) = 0
    vertexList(3) = 5: vertexList(4) = 7: vertexList(5) = 0
    vertexList(6) = 6: vertexList(7) = 7: vertexList(8) = 0
    vertexList(9) = 4: vertexList(10) = 6: vertexList(11) = 0
    vertexList(12) = 5: vertexList(13) = 6: vertexList(14) = 0
    vertexList(15) = 6: vertexList(16) = 6: vertexList(17) = 6
    ' Create the line in model space
    Set mLineObj = ThisDrawing.ModelSpace.AddMLine(vertexList)
    MsgBox "A new MLine has been added to the drawing."
(defun c:Example_AddMLine()
    ;; This example adds an Mline in model space
    ;; Define data for new object
    (setq vertexList (vlax-make-safearray vlax-vbDouble '(0 . 17)))
    (vlax-safearray-fill vertexList '(4 7 0
                                      5 7 0
                                      6 7 0
                                      4 6 0
                                      5 6 0
                                      6 6 0
    ;; Create the line in model space
    (setq mLineObj (vla-AddMLine modelSpace vertexList))
    (vla-ZoomAll acadObj)
    (alert "A new MLine has been added to the drawing.")
GMT+8, 2026-11-13 13:40
