AddMLeader 方法 (ActiveX)
在给定坐标的情况下创建一条 mleader 线。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddMLeader(pointsArray, leaderLineIndex) 返回值 (RetVal)类型:MLeader的 新创建的对象。MLeader 言论没有其他评论。 例子VBA: Sub Example_AddMLeader()
Dim oML As AcadMLeader
Dim points(0 To 14) As Double
' Define the leader points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
Dim i As Long
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
可视化 LISP: (vl-load-com)
(defun c:Example_AddMLeader()
;; Define the leader points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 14)))
(vlax-safearray-fill points '(1 1 0
1 2 0
2 2 0
3 2 0
4 4 0
(setq i 0)
;; Add the mleader object to model space
(setq mLeader (vla-AddMLeader modelSpace points i))
GMT+8, 2026-11-12 12:25
