AddFitPoint 方法 (ActiveX)
将拟合点添加到给定索引处的样条曲线。 支持的平台:仅限 Windows 签名VBA: object.AddFitPoint Index, FitPoint
返回值 (RetVal)无返回值。 言论AutoCAD 将添加该点,并在新点集中重新调整样条。若要查看更改,请使用 or 方法。UpdateRegen 例子VBA: Sub Example_AddFitPoint()
' This example creates a spline object in model space.
' It then adds a fit point to the spline.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create the spline object
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
MsgBox "The Spline has " & splineObj.NumberOfFitPoints & " fit points.", , "AddFitPoint Example"
' Define the new fit point
Dim newFitPoint(0 To 2) As Double
newFitPoint(0) = 8: newFitPoint(1) = 5: newFitPoint(2) = 0
' Add the new fit point at the first index in the spline's array of points
splineObj.AddFitPoint 1, newFitPoint
ThisDrawing.Regen True
MsgBox "A fit point has been added at Index:1 WCS: 8, 5, 0" & vbCrLf & "The Spline has " & splineObj.NumberOfFitPoints & " fit points.", , "AddFitPoint Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AddFitPoint()
;; This example creates a spline object in model space.
;; It then adds a fit point to the spline.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 10)
endTan (vlax-3d-point 0.5 0.5 10))
(setq fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 10
5 5 10
10 0 10
;; Create the spline object
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
(alert (strcat "The Spline has " (itoa (vla-get-NumberOfFitPoints splineObj)) " fit points."))
;; Define the new fit point
(setq newFitPoint (vlax-3d-point 8 5 0))
;; Add the new fit point at the first index in the spline's array of points
(vla-AddFitPoint splineObj 1 newFitPoint)
(vla-Regen doc :vlax-true)
(alert (strcat "A fit point has been added at Index:1 WCS: 8, 5, 0"
"\nThe Spline has " (itoa (vla-get-NumberOfFitPoints splineObj)) " fit points."
GMT+8, 2026-11-15 15:19
