AddEllipticalCylinder 方法 (ActiveX)
2024-5-18 18:20| 发布者: admin| 查看: 934| 评论: 0|原作者: admin|来自: AutoCAD
创建一个 3D 实体椭圆柱体,其底位于 WCS 的 XY 平面上,给定 Center、MajorRadius、MinorRadius 和 Height。
RetVal = object.AddEllipticalCylinder(Center, MajorRadius, MinorRadius, Height)
类型:块、模型空间、纸空间
此方法应用到的对象。
中心
访问:仅输入
类型:变体(双打的三元素阵列)
指定边界框中心的 3D WCS 坐标。
MajorRadius
访问:仅输入
类型:双
椭圆底的主要半径的长度。必须为正数。
小半径
访问:仅输入
类型:双
椭圆底的短半径的长度。必须为正数。
高度
访问:仅输入
类型:双
圆柱体的高度。必须为正数。
返回值 (RetVal)
类型: 3DSolid
作为新创建的椭圆柱体的对象。3DSolid
Sub Example_AddEllipticalCylinder()
    ' This example creates an elliptical cylinder in model space.
    Dim cylinderObj As Acad3DSolid
    Dim center(0 To 2) As Double
    Dim majorRadius As Double
    Dim minorRadius As Double
    Dim height As Double
    ' Define the elliptical cylinder
    center(0) = 0#: center(1) = 0#: center(2) = 0#
    majorRadius = 5#
    minorRadius = 2.5
    height = 10#
    ' Create the elliptical cylinder in model space
    Set cylinderObj = ThisDrawing.ModelSpace.AddEllipticalCylinder(center, majorRadius, minorRadius, height)
    ' Change the viewing direction of the viewport to better see the cylinder
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_AddEllipticalCylinder()
    ;; This example creates an elliptical cylinder in model space.
    ;; Define the elliptical cylinder
    (setq center (vlax-3d-point 0 0 0)
          majorRadius 5
          minorRadius 2.5
          height 10)
    ;; Create the elliptical cylinder in model space
    (setq cylinderObj (vla-AddEllipticalCylinder modelSpace center majorRadius minorRadius height))
    ;; Change the viewing direction of the viewport to better see the cylinder
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-11-12 12:48
