AddDimArc 方法 (ActiveX)
创建圆弧的圆弧长度尺寸。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddDimArc(ArcCenter, FirstEndPoint, SecondEndPoint, ArcPoint) 言论![]() ArcCenter 是要标注尺寸的圆弧的中心。FirstEndPoint 和 SecondEndPoint 是两条延伸线经过的点。 例子VBA: Sub Example_AddDimArc()
Dim PI As Double: PI = 3.141592
Dim oMS As AcadModelSpace
Set oMS = ThisDrawing.ModelSpace
Dim ptCenter(2) As Double
Dim oA As AcadArc
Set oA = oMS.AddArc(ptCenter, 10, PI / 3, PI * 3 / 4)
Dim ptArcPoint(2) As Double
ptArcPoint(0) = 0: ptArcPoint(1) = 15
Dim oAcadDimArcLength As AcadDimArcLength
Set oAcadDimArcLength = oMS.AddDimArc(oA.Center, oA.startPoint, oA.endPoint, ptArcPoint)
Update
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_AddDimArc()
;; This example creates an arc and arc length dimension in model space.
;; Define the arc
(setq center (vlax-3d-point 0 0 0))
;; Create the arc in model space
(setq arc (vla-AddArc modelSpace center 10 (/ PI 3) (/ (* PI 3) 4)))
;; Define the arc length dimension
(setq arcPoint (vlax-3d-point 0 15 0)
startPoint (vla-get-StartPoint arc)
endPoint (vla-get-EndPoint arc))
;; Create the arc length dimension in model space
(setq dimArcLength (vla-AddDimArc modelSpace center startPoint endPoint arcPoint))
(vla-ZoomExtents acadObj)
GMT+8, 2026-11-14 18:28
