AddDim3PointAngular 方法 (ActiveX)
使用 3 个点创建角度尺寸。 支持的平台:仅限 Windows 签名VBA: RetVal = object.AddDim3PointAngular(AngleVertex, FirstEndPoint, SecondEndPoint, TextPoint) 言论没有其他评论。 例子VBA: Sub Example_AddDim3PointAngular()
' This example creates a Dim3PointAngular object in model space
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 2: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
MsgBox "A Dim3PointAngular object has been created."
可视化 LISP: (vl-load-com)
(defun c:Example_AddDim3PointAngular()
;; This example creates a Dim3PointAngular object in model space
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 2 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq dimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
(alert "A Dim3PointAngular object has been created.")
GMT+8, 2026-11-12 13:02
