关于启用应用程序级事件 (VBA/ActiveX)
在使用应用程序级事件之前,必须创建一个新的类模块,并使用事件声明一个类型的对象。AcadApplication 例如,假定创建了一个新的类模块并命名为 EventClassModule。新的类模块包含使用 VBA 关键字的应用程序声明。WithEvents 将图形拖放到 AutoCAD 中时提示继续本示例在将文件拖放到 AutoCAD 中时截获加载过程。一个消息框,其中包含删除的文件的名称和“是/否/继续”按钮,允许用户决定是否应继续加载或显示文件。如果用户选择取消操作,则通过事件的 Cancel 参数返回该决定,并且不会加载文件。BeginFileDrop Public WithEvents ACADApp As AcadApplication
Sub Example_AcadApplication_Events()
' This example intializes the public variable (ACADApp)
' which will be used to intercept AcadApplication Events
' Run this procedure FIRST!
' We could get the application from the ThisDocument
' object, but that would require having a drawing open,
' so we grab it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application.23")
Private Sub ACADApp_BeginFileDrop _
(ByVal FileName As String, Cancel As Boolean)
' This example intercepts an Application BeginFileDrop event.
' This event is triggered when a drawing file is dragged
' into AutoCAD.
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Drag an AutoCAD drawing file into the AutoCAD
' application from either the Windows Desktop
' or Windows Explorer
' Use the "Cancel" variable to stop the loading of the
' dragged file, and the "FileName" variable to notify
' the user which file is about to be dragged in.
If MsgBox("AutoCAD is about to load " & FileName & vbCrLf _
& "Do you want to continue loading this file?", _
vbYesNoCancel + vbQuestion) <> vbYes Then
Cancel = True
End If
GMT+8, 2026-11-14 14:50
