关于对齐行文本 (VBA/ActiveX)
2024-5-18 18:19| 发布者: admin| 查看: 762| 评论: 0|原作者: admin|来自: AutoCAD
您可以水平和垂直对齐行文本。左对齐是默认设置。若要设置水平和垂直对齐选项,请使用该属性。Alignment
重新对齐文本
此示例创建一个对象和一个对象。对象设置为文本对齐点,并更改为红色十字准线,以便可见。更改文本对齐方式并显示一个消息框,以便停止宏执行。这使您可以查看更改文本对齐方式的影响。TextPointPoint
Sub Ch4_TextAlignment()
  Dim textObj As AcadText
  Dim textString As String
  Dim height As Double
  ' Define the new Text object
  textString = "Hello, World."
  insertionPoint(0) = 3
  insertionPoint(1) = 3
  insertionPoint(2) = 0
  height = 0.5
  ' Create the Text object in model space
  Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
  ' Create a point over the text alignment point,
  ' so we can better visualize the alignment process
  Dim pointObj As AcadPoint
  Dim alignmentPoint(0 To 2) As Double
  alignmentPoint(0) = 3
  alignmentPoint(1) = 3
  alignmentPoint(2) = 0
  Set pointObj = ThisDrawing.ModelSpace.AddPoint(alignmentPoint)
  pointObj.Color = acRed
  ' Set the point style to crosshair
  ThisDrawing.SetVariable "PDMODE", 2
  ' Align the text to the Left
  textObj.Alignment = acAlignmentLeft
  ThisDrawing.Regen acActiveViewport
  MsgBox "The Text object is now aligned left"
  ' Align the text to the Center
  textObj.Alignment = acAlignmentCenter
  ' Align the text to the point (necessary for
  ' all but left aligned text.)
  textObj.TextAlignmentPoint = alignmentPoint
  MsgBox "The Text object is now centered"
  ' Align the text to the Right
  textObj.Alignment = acAlignmentRight
  MsgBox "The Text object is now aligned right"
GMT+8, 2026-11-13 13:45
