关于旋转对象 (VBA/ActiveX)
可以旋转所有图形对象和属性参照对象。 若要旋转对象,请使用为该对象提供的方法。此方法需要输入基点和旋转角度。基点是具有三个双精度的变体数组。这些双精度表示 3D WCS 坐标,指定定义旋转轴的点。旋转角度以弧度为单位指定。此角度决定了对象相对于其当前位置围绕基点旋转的距离。Rotate ![]() 绕基点旋转折线本示例创建闭合的轻量级折线,然后将折线绕基点 (4, 4.25, 0) 旋转 45 度。 Sub Ch4_RotatePolyline() ' Create the polyline Dim plineObj As AcadLWPolyline Dim points(0 To 11) As Double points(0) = 1: points(1) = 2 points(2) = 1: points(3) = 3 points(4) = 2: points(5) = 3 points(6) = 3: points(7) = 3 points(8) = 4: points(9) = 4 points(10) = 4: points(11) = 2 Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points) plineObj.Closed = True ZoomAll ' Define the rotation of 45 degrees about a ' base point of (4, 4.25, 0) Dim basePoint(0 To 2) As Double Dim rotationAngle As Double basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0 rotationAngle = 0.7853981 ' 45 degrees ' Rotate the polyline plineObj.Rotate basePoint, rotationAngle plineObj.Update End Sub 相关概念父主题: |
GMT+8, 2026-11-12 12:29
