AutoCAD 2000 API 历史记录参考 (ActiveX)
2024-5-18 18:19| 发布者: admin| 查看: 835| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2000 和基于 AutoCAD 2000 的产品中的 ActiveX API 所做的添加和更改。
常数
删除了以下内容:
AutoCADConstants
        acTrue = 1;
        acFalse = 0;
        acOn = 1;
        acOff = 0;
        ac3dFace = 1;
        ac3dPolyline = 2;
        ac3dSolid = 3;
        acArc = 4;
        acAttribute = 5;
        acAttributeReference = 6;
        acBlockReference = 7;
        acCircle = 8;
        acDimAligned = 9;
        acDimAngular = 10;
        acDimDiametric = 12;
        acDimOrdinate = 13;
        acDimRadial = 14;
        acDimRotated = 15;
        acEllipse = 16;
        acHatch = 17;
        acLeader = 18;
        acLine = 19;
        acMtext = 21;
        acPoint = 22;
        acPolyline = 23;
        acPolylineLight = 24;
        acPolymesh = 25;
        acRaster = 26;
        acRay = 27;
        acRegion = 28;
        acShape = 29;
        acSolid = 30;
        acSpline = 31;
        acText = 32;
        acTolerance = 33;
        acTrace = 34;
        acPViewport = 35;
        acXline = 36;
        acGroup = 37;
        acModelSpace = 1;
        acPaperSpace = 0;
        acPreferenceClassic = 0;
        acPreferenceCustom = 1;
        acPlotOrientationPortrait = 0;
        acPlotOrientationLandscape = 1;
        acByBlock = 0;
        acRed = 1;
        acYellow = 2;
        acGreen = 3;
        acCyan = 4;
        acBlue = 5;
        acMagenta = 6;
        acWhite = 7;
        acByLayer = 256;
        acAttachmentPointTopLeft = 1;
        acAttachmentPointTopCenter = 2;
        acAttachmentPointTopRight = 3;
        acAttachmentPointMiddleLeft = 4;
        acAttachmentPointMiddleCenter = 5;
        acAttachmentPointMiddleRight = 6;
        acAttachmentPointBottomLeft = 7;
        acAttachmentPointBottomCenter = 8;
        acAttachmentPointBottomRight = 9;
        acLeftToRight = 1;
        acRightToLeft = 2;
        acTopToBottom = 3;
        acBottomToTop = 4;
        acLineNoArrow = 0;
        acSplineNoArrow = 1;
        acLineWithArrow = 2;
        acSplineWithArrow = 3;
        acAttributeModeInvisible = 1;
        acAttributeModeConstant = 2;
        acAttributeModeVerify = 4;
        acAttributeModePreset = 8;
        acHorizontalAlignmentLeft = 0;
        acHorizontalAlignmentCenter = 1;
        acHorizontalAlignmentRight = 2;
        acHorizontalAlignmentAligned = 3;
        acHorizontalAlignmentMiddle = 4;
        acHorizontalAlignmentFit = 5;
        acVerticalAlignmentBaseline = 0;
        acVerticalAlignmentBottom = 1;
        acVerticalAlignmentMiddle = 2;
        acVerticalAlignmentTop = 3;
        acTextFlagBackward = 2;
        acTextFlagUpsideDown = 4;
        acSelectionSetWindow = 0;
        acSelectionSetCrossing = 1;
        acSelectionSetFence = 2;
        acSelectionSetPrevious = 3;
        acSelectionSetLast = 4;
        acSelectionSetAll = 5;
        acSelectionSetWindowPolygon = 6;
        acSelectionSetCrossingPolygon = 7;
        acHatchPatternTypeUserDefined = 0;
        acHatchPatternTypePreDefined = 1;
        acHatchPatternTypeCustomDefined = 2;
        acHatchLoopTypeDefault = 0;
        acHatchLoopTypeExternal = 1;
        acHatchLoopTypePolyline = 2;
        acHatchLoopTypeDerived = 4;
        acHatchLoopTypeTextbox = 8;
        acHatchStyleNormal = 0;
        acHatchStyleOuter = 1;
        acHatchStyleIgnore = 2;
        acOsnapEnd = 1;
        acOsnapMid = 2;
        acOsnapCenter = 3;
        acOsnapNode = 4;
        acOsnapQuadrant = 5;
        acOsnapInsert = 6;
        acOsnapPerpendicular = 7;
        acOsnapTangent = 8;
        acOsnapNear = 9;
        acSimplePoly = 0;
        acFitCurvePoly = 1;
        acQuadSplinePoly = 2;
        acCubicSplinePoly = 3;
        acViewport2Horizontal = 0;
        acViewport2Vertical = 1;
        acViewport3Left = 2;
        acViewport3Right = 3;
        acViewport3Horizontal = 4;
        acViewport3Vertical = 5;
        acViewport3Above = 6;
        acViewport3Below = 7;
        acViewport4 = 8;
        acActiveViewport = 0;
        acAllViewports = 1;
        acAmericanEnglish = "enu";
        acAustralianEnglish = "ena";
        acBritishEnglishIse = "ens";
        acBritishEnglishIze = "enz";
        acCatalan = "ca";
        acCzech = "cs";
        acDanish = "da";
        acDutchPrim = "nl";
        acDutchSec = "nls";
        acFinnish = "fi";
        acFrenchUnaccentCap = "fr";
        acFrenchAccentCap = "fra";
        acGermanScharfesS = "de";
        acGermanDoppleS = "ded";
        acItalian = "it";
        acNorwegianBokmal = "no";
        acNorwegianNynorsk = "non";
        acPortugueseIberian = "pt";
        acPortugueseBrazilian = "ptb";
        acRussianInfrequentIo = "ru";
        acRussianFrequentIo = "rui";
        acSpanishUnaccentCap = "es";
        acSpanishAccentCap = "esa";
        acSwedish = "sv";
        acUnion = 0;
        acIntersection = 1;
        acSubtraction = 2;
        acExtendNone = 0;
        acExtendThisEntity = 1;
        acExtendOtherEntity = 2;
        acExtendBoth = 3;
        acDegrees = 0;
        acDegreeMinuteSeconds = 1;
        acGrads = 2;
        acRadians = 3;
        acSurveyorUnits = 4;
        acScientific = 1;
        acDecimal = 2;
        acEngineering = 3;
        acArchitectural = 4;
        acFractional = 5;
        acWorld = 0;
        acUCS = 1;
        acDisplayDCS = 2;
        acPaperSpaceDCS = 3;
        acEnglish = 0;
        acMetric = 1;
        acDemandLoadDisabled = 0;
        acDemandLoadEnabled = 1;
        acDemandLoadEnabledWithCopy = 2;
        acPartialPreview = 0;
        acFullPreview = 1;
        acSimpleMesh = 0;
        acQuadSurfaceMesh = 5;
        acCubicSurfaceMesh = 6;
        acBezierSurfaceMesh = 8;
        acZoomScaledAbsolute = 0;
        acZoomScaledRelative = 1;
        acZoomScaledRelativePSpace = 2;
        acDragDoNotDisplay = 0;
        acDragDisplayOnRequest = 1;
        acDragDisplayAutomatically = 2;
        acDemanLoadDisable = 0;
        acDemandLoadOnObjectDetect = 1;
        acDemandLoadCmdInvoke = 2;
        acFontRegular = 0;
        acFontItalic = 1;
        acFontBold = 2;
        acFontBoldItalic = 3;
        acProxyNotShow = 0;
        acProxyShow = 1;
        acProxyBoundingBox = 2;
        acKeyboardRunningObjSnap = 0;
        acKeyboardEntry = 1;
        acKeyboardProxyNoScripts = 2;
枚举
AcBoolean (New)
        acFalse = 0
        acTrue = 1
AcOnOff (New)
        acOff = 0
        acOn = 1
AcEntityName (New)
        ac3dFace = 1
        ac3dPolyline = 2
        ac3dSolid = 3
        acArc = 4
        acAttribute = 5
        acCircle = 8
        acDimAligned = 9
        acDimAngular = 10
        acDimDiametric = 12
        acDimOrdinate = 13
        acDimRadial = 14
        acDimRotated = 15
        acEllipse = 16
        acHatch = 17
        acLeader = 18
        acLine = 19
        acMtext = 21
        acPoint = 22
        acPolyline = 23
        acPolymesh = 25
        acRaster = 26
        acRay = 27
        acRegion = 28
        acShape = 29
        acSolid = 30
        acSpline = 31
        acText = 32
        acTolerance = 33
        acTrace = 34
        acPViewport = 35
        acXline = 36
        acGroup = 37
        acMInsertBlock = 38
        acPolyfaceMesh = 39
        acMLine = 40
        acDim3PointAngular = 41
        acExternalReference = 42
AcActiveSpace (New)
        acPaperSpace = 0
        acModelSpace = 1
AcKeyboardAccelerator (New)
AcPlotOrientation (New)
AcColor (New)
        acByBlock = 0
        acRed = 1
        acYellow = 2
        acGreen = 3
        acCyan = 4
        acBlue = 5
        acMagenta = 6
        acWhite = 7
        acByLayer = 256
AcAttachmentPoint (New)
AcDrawingDirection (New)
        acLeftToRight = 1
        acRightToLeft = 2
        acTopToBottom = 3
        acBottomToTop = 4
        acByStyle = 5
AcLeaderType (New)
        acLineNoArrow = 0
        acSplineNoArrow = 1
        acLineWithArrow = 2
AcAttributeMode (New)
        acAttributeModeNormal = 0
AcHorizontalAlignment (New)
AcVerticalAlignment (New)
AcTextGenerationFlag (New)
AcSelect (New)
AcPatternType (New)
AcLoopType (New)
AcHatchStyle (New)
AcPolylineType (New)
        acSimplePoly = 0
        acFitCurvePoly = 1
Ac3DPolylineType (New)
        acSimple3DPoly = 0
        acQuadSpline3DPoly = 1
        acCubicSpline3DPoly = 2
AcViewportSplitType (New)
        acViewport3Left = 2
        acViewport4 = 8
AcRegenType (New)
        acAllViewports = 1
AcBooleanType (New)
        acUnion = 0
        acIntersection = 1
        acSubtraction = 2
AcExtendOption (New)
        acExtendNone = 0
        acExtendBoth = 3
AcAngleUnits (New)
        acDegrees = 0
        acGrads = 2
        acRadians = 3
AcUnits (New)
        acDefaultUnits = 0xffffffff
        acScientific = 1
        acDecimal = 2
        acEngineering = 3
        acArchitectural = 4
        acFractional = 5
AcCoordinateSystem (New)
        acWorld = 0
        acUCS = 1
        acDisplayDCS = 2
        acPaperSpaceDCS = 3
        acOCS = 4
AcMeasurementUnits (New)
        acEnglish = 0
        acMetric = 1
AcXRefDemandLoad (New)
AcPreviewMode (New)
        acFullPreview = 1
AcPolymeshType (New)
        acSimpleMesh = 0
AcZoomScaleType (New)
AcDragDisplayMode (New)
AcARXDemandLoad (New)
AcTextFontStyle (New)
        acFontRegular = 0
        acFontItalic = 1
        acFontBold = 2
AcProxyImage (New)
        acProxyNotShow = 0
        acProxyShow = 1
AcKeyboardPriority (New)
        acKeyboardEntry = 1
        acKeyboardEntryExceptScripts = 2
AcMenuGroupType (New)
        acBaseMenuGroup = 0
        acPartialMenuGroup = 1
AcMenuFileType (New)
        acMenuFileCompiled = 0
        acMenuFileSource = 1
AcMenuItemType (New)
        acMenuItem = 0
        acMenuSeparator = 1
        acMenuSubMenu = 2
AcToolbarItemType (New)
        acToolbarButton = 0
        acToolbarSeparator = 1
        acToolbarControl = 2
        acToolbarFlyout = 3
AcToolbarDockStatus (New)
        acToolbarDockTop = 0
        acToolbarDockBottom = 1
        acToolbarDockLeft = 2
        acToolbarDockRight = 3
        acToolbarFloating = 4
AcLineWeight (New)
        acLnWt000 = 0
        acLnWt005 = 5
        acLnWt009 = 9
        acLnWt013 = 13
        acLnWt015 = 15
        acLnWt018 = 18
        acLnWt020 = 20
        acLnWt025 = 25
        acLnWt030 = 30
        acLnWt035 = 35
        acLnWt040 = 40
        acLnWt050 = 50
        acLnWt053 = 53
        acLnWt060 = 60
        acLnWt070 = 70
        acLnWt080 = 80
        acLnWt090 = 90
        acLnWt100 = 100
        acLnWt106 = 106
        acLnWt120 = 120
        acLnWt140 = 140
        acLnWt158 = 158
        acLnWt200 = 200
        acLnWt211 = 211
        acLnWtByLayer = 0xffffffff
        acLnWtByBlock = 0xfffffffe
        acLnWtByLwDefault = 0xfffffffd
AcWindowState (New)
        acNorm = 1
        acMin = 2
        acMax = 3
AcPlotPaperUnits (New)
        acInches = 0
        acMillimeters = 1
        acPixels = 2
AcPlotRotation (New)
        ac0degrees = 0
        ac90degrees = 1
        ac180degrees = 2
        ac270degrees = 3
AcPlotType (New)
        acDisplay = 0
        acExtents = 1
        acLimits = 2
        acView = 3
        acWindow = 4
        acLayout = 5
AcPlotScale (New)
        acScaleToFit = 0
        ac1_128in_1ft = 1
        ac1_64in_1ft = 2
        ac1_32in_1ft = 3
        ac1_16in_1ft = 4
        ac3_32in_1ft = 5
        ac1_8in_1ft = 6
        ac3_16in_1ft = 7
        ac1_4in_1ft = 8
        ac3_8in_1ft = 9
        ac1_2in_1ft = 10
        ac3_4in_1ft = 11
        ac1in_1ft = 12
        ac3in_1ft = 13
        ac6in_1ft = 14
        ac1ft_1ft = 15
        ac1_1 = 16
        ac1_2 = 17
        ac1_4 = 18
        ac1_8 = 19
        ac1_10 = 20
        ac1_16 = 21
        ac1_20 = 22
        ac1_30 = 23
        ac1_40 = 24
        ac1_50 = 25
        ac1_100 = 26
        ac2_1 = 27
        ac4_1 = 28
        ac8_1 = 29
        ac10_1 = 30
        ac100_1 = 31
AcAlignment (New)
        acAlignmentLeft = 0
        acAlignmentCenter = 1
        acAlignmentRight = 2
        acAlignmentAligned = 3
        acAlignmentMiddle = 4
        acAlignmentFit = 5
        acAlignmentTopLeft = 6
        acAlignmentTopCenter = 7
        acAlignmentTopRight = 8
        acAlignmentMiddleLeft = 9
        acAlignmentMiddleCenter = 10
        acAlignmentMiddleRight = 11
        acAlignmentBottomLeft = 12
        acAlignmentBottomCenter = 13
        acAlignmentBottomRight = 14
ACAD_COLOR (New)
ACAD_LAYER (New)
ACAD_LTYPE (New)
ACAD_NULL (New)
ACAD_DISTANCE (New)
ACAD_ANGLE (New)
ACAD_LWEIGHT (New)
ACAD_NOUNITS (New)
ACAD_POINT (New)
AcLineSpacingStyle (New)
        acLineSpacingStyleAtLeast = 1
        acLineSpacingStyleExactly = 2
AcDimPrecision (New)
        acDimPrecisionZero = 0
        acDimPrecisionOne = 1
        acDimPrecisionTwo = 2
        acDimPrecisionThree = 3
        acDimPrecisionFour = 4
        acDimPrecisionFive = 5
        acDimPrecisionSix = 6
        acDimPrecisionSeven = 7
        acDimPrecisionEight = 8
AcDimUnits (New)
        acDimScientific = 1
        acDimDecimal = 2
        acDimEngineering = 3
        acDimArchitecturalStacked = 4
        acDimFractionalStacked = 5
        acDimArchitectural = 6
        acDimFractional = 7
        acDimWindowsDesktop = 8
AcDimLUnits (New)
        acDimLScientific = 1
        acDimLDecimal = 2
        acDimLEngineering = 3
        acDimLArchitectural = 4
        acDimLFractional = 5
        acDimLWindowsDesktop = 6
AcDimArrowheadType (New)
        acArrowDefault = 0
        acArrowClosedBlank = 1
        acArrowClosed = 2
        acArrowDot = 3
        acArrowArchTick = 4
        acArrowOblique = 5
        acArrowOpen = 6
        acArrowOrigin = 7
        acArrowOrigin2 = 8
        acArrowOpen90 = 9
        acArrowOpen30 = 10
        acArrowDotSmall = 11
        acArrowDotBlank = 12
        acArrowSmall = 13
        acArrowBoxBlank = 14
        acArrowBoxFilled = 15
        acArrowDatumBlank = 16
        acArrowDatumFilled = 17
        acArrowIntegral = 18
        acArrowNone = 19
        acArrowUserDefined = 20
AcDimCenterType (New)
        acCenterMark = 0
        acCenterLine = 1
        acCenterNone = 2
AcDimFit (New)
        acTextAndArrows = 0
        acArrowsOnly = 1
        acTextOnly = 2
        acBestFit = 3
AcDimFractionType (New)
        acHorizontal = 0
        acDiagonal = 1
        acNotStacked = 2
AcDimHorizontalJustification (New)
        acHorzCentered = 0
        acFirstExtensionLine = 1
        acSecondExtensionLine = 2
        acOverFirstExtension = 3
        acOverSecondExtension = 4
AcDimVerticalJustification (New)
        acVertCentered = 0
        acAbove = 1
        acOutside = 2
        acJIS = 3
AcDimTextMovement (New)
        acDimLineWithText = 0
        acMoveTextAddLeader = 1
        acMoveTextNoLeader = 2
AcDimToleranceMethod (New)
        acTolNone = 0
        acTolSymmetrical = 1
        acTolDeviation = 2
        acTolLimits = 3
        acTolBasic = 4
AcDimToleranceJustify (New)
        acTolBottom = 0
        acTolMiddle = 1
        acTolTop = 2
AcViewportScale (New)
        acVpScaleToFit = 0
        acVpCustomScale = 1
        acVp1_1 = 2
        acVp1_2 = 3
        acVp1_4 = 4
        acVp1_8 = 5
        acVp1_10 = 6
        acVp1_16 = 7
        acVp1_20 = 8
        acVp1_30 = 9
        acVp1_40 = 10
        acVp1_50 = 11
        acVp1_100 = 12
        acVp2_1 = 13
        acVp4_1 = 14
        acVp8_1 = 15
        acVp10_1 = 16
        acVp100_1 = 17
        acVp1_128in_1ft = 18
        acVp1_64in_1ft = 19
        acVp1_32in_1ft = 20
        acVp1_16in_1ft = 21
        acVp3_32in_1ft = 22
        acVp1_8in_1ft = 23
        acVp3_16in_1ft = 24
        acVp1_4in_1ft = 25
        acVp3_8in_1ft = 26
        acVp1_2in_1ft = 27
        acVp3_4in_1ft = 28
        acVp1in_1ft = 29
        acVp3in_1ft = 30
        acVp6in_1ft = 31
        acVp1ft_1ft = 32
AcISOPenWidth (New)
        acPenWidth013 = 13
        acPenWidth018 = 18
        acPenWidth025 = 25
        acPenWidth035 = 35
        acPenWidth050 = 50
        acPenWidth070 = 70
        acPenWidth100 = 100
        acPenWidth140 = 140
        acPenWidth200 = 200
        acPenWidthUnk = 0xffffffff
AcSaveAsType (New)
        acUnknown = 0xffffffff
        acR12_dxf = 1
        acR13_dwg = 4
        acR13_dxf = 5
        acR14_dwg = 8
        acR14_dxf = 9
        acR15_dwg = 12
        acR15_dxf = 13
        acR15_Template = 14
        acNative = 12
AcPrinterSpoolAlert (New)
        acPrinterAlwaysAlert = 0
        acPrinterAlertOnce = 1
        acPrinterNeverAlertLogOnce = 2
        acPrinterNeverAlert = 3
AcPlotPolicyForNewDwgs (New)
        acPolicyNewDefault = 0
        acPolicyNewLegacy = 1
AcPlotPolicyForLegacyDwgs (New)
        acPolicyLegacyDefault = 0
        acPolicyLegacyQuery = 1
        acPolicyLegacyLegacy = 2
AcOleQuality (New)
        acOQLineArt = 0
        acOQText = 1
        acOQGraphics = 2
        acOQPhoto = 3
        acOQHighPhoto = 4
AcLoadPalette (New)
        acPaletteByDrawing = 0
        acPaletteBySession = 1
AcInsertUnits (New)
        acInsertUnitsUnitless = 0
        acInsertUnitsInches = 1
        acInsertUnitsFeet = 2
        acInsertUnitsMiles = 3
        acInsertUnitsMillimeters = 4
        acInsertUnitsCentimeters = 5
        acInsertUnitsMeters = 6
        acInsertUnitsKilometers = 7
        acInsertUnitsMicroinches = 8
        acInsertUnitsMils = 9
        acInsertUnitsYards = 10
        acInsertUnitsAngstroms = 11
        acInsertUnitsNanometers = 12
        acInsertUnitsMicrons = 13
        acInsertUnitsDecimeters = 14
        acInsertUnitsDecameters = 15
        acInsertUnitsHectometers = 16
        acInsertUnitsGigameters = 17
        acInsertUnitsAstronomicalUnits = 18
        acInsertUnitsLightYears = 19
        acInsertUnitsParsecs = 20
AcAlignmentPointAcquisition (New)
        acAlignPntAcquisitionAutomatic = 0
        acAlignPntAcquisitionShiftToAcquire = 1
AcInsertUnitsAction (New)
        acInsertUnitsPrompt = 0
        acInsertUnitsAutoAssign = 1
AcPlotPolicy (New)
        acPolicyNamed = 0
        acPolicyLegacy = 1
AcDrawingAreaShortCutMenu
        acNoDrawingAreaShortCutMenu = 0
        acUseDefaultDrawingAreaShortCutMenu = 1
AcDrawingAreaSCMDefault
        acRepeatLastCommand = 0
        acSCM = 1
AcDrawingAreaSCMEdit
        acEdRepeatLastCommand = 0
        acEdSCM = 1
AcDrawingAreaSCMCommand
        acEnter = 0
        acEnableSCMOptions = 1
        acEnableSCM = 2
类
IAcadObject (Changed)
        Handle - Property
        ObjectName - Property (New)
        Name - Property (Removed)
        GetXData - Method
        SetXData - Method
        Delete - Method (New)
        ObjectID - Property
        Application - Property
        Database - Property (New)
        HasExtensionDictionary - Property (New)
        GetExtensionDictionary - Method (New)
        OwnerID - Property (New)
        Document - Property (New)
IAcadDatabase (New)
        ModelSpace - Property
        PaperSpace - Property
        Blocks - Property
        CopyObjects - Method
        Groups - Property
        DimStyles - Property
        Layers - Property
        Linetypes - Property
        Dictionaries - Property
        RegisteredApplications - Property
        TextStyles - Property
        UserCoordinateSystems - Property
        Views - Property
        Viewports - Property
        ElevationModelSpace - Property
        ElevationPaperSpace - Property
        Limits - Property
        HandleToObject - Method
        ObjectIdToObject - Method
        Layouts - Property
        PlotConfigurations - Property
        Preferences - Property
IAcadModelSpace (Changed)
        Item - Method
        Count - Property
        Name - Property
        Origin - Property (New)
        AddCustomObject - Method
        Add3DFace - Method
        Add3DMesh - Method
        Add3DPoly - Method
        AddArc - Method
        AddAttribute - Method
        AddBox - Method
        AddCircle - Method
        AddCone - Method
        AddCylinder - Method
        AddDimAligned - Method
        AddDimAngular - Method
        AddDimDiametric - Method
        AddDimRotated - Method
        AddDimOrdinate - Method
        AddDimRadial - Method
        AddEllipse - Method
        AddEllipticalCone - Method
        AddEllipticalCylinder - Method
        AddExtrudedSolid - Method
        AddExtrudedSolidAlongPath - Method
        AddLeader - Method
        AddMText - Method
        AddPoint - Method
        AddLightWeightPolyline - Method
        AddPolyline - Method
        AddRay - Method
        AddRegion - Method
        AddRevolvedSolid - Method
        AddShape - Method
        AddSolid - Method
        AddSphere - Method
        AddSpline - Method
        AddText - Method
        AddTolerance - Method
        AddTorus - Method
        AddTrace - Method
        AddWedge - Method
        AddXline - Method
        InsertBlock - Method
        AddHatch - Method
        AddRaster - Method
        AddLine - Method
        IsLayout - Property (New)
        IsXRef - Property (New)
        AddMInsertBlock - Method (New)
        AddPolyfaceMesh - Method (New)
        AddMLine - Method (New)
        AddDim3PointAngular - Method (New)
        XRefDatabase - Property (New)
        AttachExternalReference - Method (New)
        Unload - Method (New)
        Reload - Method (New)
        Bind - Method (New)
        Detach - Method (New)
        Handle - Property (Removed)
IAcadBlock (Changed)
        Item - Method
        Count - Property
        Name - Property
        Origin - Property
        Add3DFace - Method
        Add3DMesh - Method
        Add3DPoly - Method
        AddArc - Method
        AddBox - Method
        AddCircle - Method
        AddCone - Method
        AddEllipse - Method
        AddLeader - Method
        AddMText - Method
        AddPoint - Method
        AddRay - Method
        AddRegion - Method
        AddShape - Method
        AddSolid - Method
        AddSphere - Method
        AddSpline - Method
        AddText - Method
        AddTorus - Method
        AddTrace - Method
        AddWedge - Method
        AddXline - Method
        AddHatch - Method
        AddRaster - Method
        AddLine - Method
        Bind - Method (New)
        Delete - Property (Removed)
IAcadEntity (Changed)
        Color - Property
        Layer - Property
        Linetype - Property
        LinetypeScale - Property
        Visible - Property
        GetXData - Method (Removed)
        SetXData - Method (Removed)
        ArrayPolar - Method
        ArrayRectangular - Method
        Highlight - Method
        Copy - Method
        Erase - Method (Removed)
        Move - Method
        Rotate - Method
        Rotate3D - Method
        Mirror - Method
        Mirror3D - Method(0x00010213)]
        ScaleEntity - Method
        TransformBy - Method
        Update - Method
        GetBoundingBox - Method
        IntersectWith - Method
        PlotStyleName - Property (New)
        Lineweight - Property (New)
        Hyperlinks - Property (New)
        EntityName - Property (New)
        EntityType - Property (New)
        ObjectID - Property (Removed)
        Application - Property (Removed)
IAcadHyperlinks (New)
        Item - Method
        Count - Property
        Add - Method
IAcadHyperlink (New)
        URL - Property
        URLDescription - Property
        Delete - Method
        URLNamedLocation - Property
IAcad3DFace (Changed)
        EntityName - Property (Removed)
        Color - Property (Removed)
        Layer - Property (Removed)
        Linetype - Property (Removed)
        LinetypeScale - Property (Removed)
        Visible - Property (Removed)
        ArrayPolar - Method (Removed)
        ArrayRectangular - Method (Removed)
        Highlight - Method (Removed)
        Copy - Method (Removed)
        Move - Method (Removed)
        Rotate - Method (Removed)
        Rotate3D - Method (Removed)
        Mirror - Method (Removed)
        Mirror3D - Method (Removed)
        ScaleEntity- Method (Removed)
        TransformBy - Method (Removed)
        Update - Method (Removed)
        GetBoundingBox - Method (Removed)
        IntersectWith - Method (Removed)
        EntityType - Property (Removed)
        Coordinates - Property (New)
        VisibilityEdge1 - Property (New)
        VisibilityEdge2 - Property (New)
        VisibilityEdge3 - Property (New)
        VisibilityEdge4 - Property (New)
        GetInvisibleEdge - Method
        SetInvisibleEdge - Method
        Coordinate - Property (New)
IAcadPolygonMesh (New)
        MClose - Property
        NClose - Property
        MDensity - Property
        NDensity - Property
        MVertexCount - Property
        NVertexCount - Property
        Type - Property
        AppendVertex - Method
        Explode - Method
IAcad3DPolyline (Changed)
        Explode - Method
        Closed - Property
IAcadArc (Changed)
        Area - Property
        Center - Property
        Radius - Property
        StartAngle - Property
        EndAngle - Property
        TotalAngle - Property (New)
        ArcLength - Property (New)
        StartPoint - Property
        EndPoint - Property
        Normal - Property
        Thickness - Property
        Offset - Method
IAcadAttribute (Changed)
        FieldLength - Property
        Height - Property
        Alignment - Property (New)
        HorizontalAlignment - Property
        InsertionPoint - Property
        Normal - Property
        ObliqueAngle - Property
        PromptString - Property
        Rotation - Property
        ScaleFactor - Property
        TagString - Property
        TextAlignmentPoint - Property
        TextGenerationFlag - Property
        TextString - Property
        VerticalAlignment - Property
        Mode - Property
        UpsideDown - Property (New)
        Backward - Property (New)
        Invisible - Property (New)
        Constant - Property (New)
        Verify - Property (New)
        Preset - Property (New)
IAcadAttributeReference (Changed)
        Height - Property
        Normal - Property
        Rotation - Property
        Backward - Property
        Constant - Property
IAcad3DSolid (Changed)
        Centroid - Property
        MomentOfInertia - Property
        PrincipalDirections - Property
        PrincipalMoments - Property
        ProductOfInertia - Property
        RadiiOfGyration - Property
        Volume - Property
        Boolean - Method
        CheckInterference - Method
        SectionSolid - Method
        SliceSolid - Method
IAcadRegion (Changed)
        Area - Property
        Centroid - Property
        Normal - Property
        Perimeter - Property
        Boolean - Method
        Explode - Method
IAcadCircle (Changed)
        Area - Property
        Center - Property
        Radius - Property
        Normal - Property
        Offset - Method
        Diameter - Property (New)
        Circumference - Property (New)
IAcadDimAligned (Changed)
        Normal - Property
        Rotation - Property
        TextPosition - Property
        TextRotation - Property
        ExtLine1Point - Property
        ExtLine2Point - Property
        AltUnits - Property (New)
        AltUnitsPrecision - Property (New)
        AltUnitsScale - Property (New)
        AltRoundDistance - Property (New)
        AltTolerancePrecision - Property (New)
        AltUnitsFormat - Property (New)
        AltTextPrefix - Property (New)
        AltTextSuffix - Property (New)
        DimensionLineColor - Property (New)
        ExtensionLineColor - Property (New)
        PrimaryUnitsPrecision - Property (New)
        DimensionLineExtend - Property (New)
        ExtensionLineExtend - Property (New)
        Fit - Property (New)
        FractionFormat - Property (New)
        HorizontalTextPosition - Property (New)
        LinearScaleFactor - Property (New)
        ExtensionLineWeight - Property (New)
        DimLine1Suppress - Property (New)
        DimLine2Suppress - Property (New)
        ExtLine1Suppress - Property (New)
        ExtLine2Suppress - Property (New)
        DimLineInside - Property (New)
        TextInsideAlign - Property (New)
        TextInside - Property (New)
        ForceLineInside - Property (New)
        TextOutsideAlign - Property (New)
        ExtensionLineOffset - Property (New)
        AltSuppressLeadingZeros - Property (New)
        AltSuppressTrailingZeros - Property (New)
        AltSuppressZeroFeet - Property (New)
        AltSuppressZeroInches - Property (New)
        AltToleranceSuppressLeadingZeros - Property (New)
        AltToleranceSuppressTrailingZeros - Property (New)
        AltToleranceSuppressZeroFeet - Property (New)
        AltToleranceSuppressZeroInches - Property (New)
        DimensionLineWeight - Property (New)
        ArrowheadSize - Property (New)
        Arrowhead1Type - Property (New)
        Arrowhead2Type - Property (New)
        Measurement - Property (New)
        Arrowhead1Block - Property (New)
        Arrowhead2Block - Property (New)
IAcadDimension (New)
        Normal - Property
        Rotation - Property
        TextOverride - Property
        TextColor - Property
        DecimalSeparator - Property
        TextGap - Property
        VerticalTextPosition - Property
        ToleranceHeightScale - Property
        ToleranceLowerLimit - Property
        TextMovement - Property
        ToleranceDisplay - Property
        ToleranceJustification - Property
        ToleranceUpperLimit - Property
        TextStyle - Property
        TextHeight - Property
IAcadDimAngular (Changed)
        Normal - Property
        Rotation - Property
        ExtLine1StartPoint - Property
        ExtLine1EndPoint - Property
        ExtLine2StartPoint - Property
        ExtLine2EndPoint - Property
        AngleFormat - Property (New)
        TextPrecision - Property (New)
IAcadDimDiametric (Changed)
        Normal - Property
        Rotation - Property
        LeaderLength - Property
        CenterType - Property (New)
        CenterMarkSize - Property (New)
IAcadDimRotated (Changed)
        Normal - Property
        Rotation - Property
IAcadDimOrdinate (Changed)
        Normal - Property
        Rotation - Property
IAcadDimRadial (Changed)
        Normal - Property
        Rotation - Property
        DimLineSuppress - Property (New)
        ArrowheadType - Property (New)
        ArrowheadBlock - Property (New)
IAcadEllipse (Changed)
        Area - Property
        EndPoint - Property
        Center - Property
        EndAngle - Property
        StartParameter - Property
        EndParameter - Property
        MajorAxis - Property
        MinorAxis - Property
        Normal - Property
        RadiusRatio - Property
        Offset - Method
        MajorRadius - Property (New)
        MinorRadius - Property (New)
IAcadLeader (Changed)
        Normal - Property
        Type - Property
        Evaluate - Method
        Annotation - Property (New)
        VerticalTextPosition - Property (New)
        TextGap - Property (New)
IAcadMtext (Removed)
        Handle - Property
        Color - Property
        Layer - Property
        Linetype - Property
        Visible - Property
        GetXData - Method
        SetXData - Method
        ArrayPolar - Method
        Highlight - Method
        Copy - Method
        Erase - Method
        Move - Method
        Rotate - Method
        Rotate3D - Method
        Mirror - Method
        Mirror3D - Method
        ScaleEntity- Method
        Update - Method
        ObjectID - Property
        AttachmentPoint - Property
        DrawingDirection - Property
        Height - Property
        Normal - Property
        Rotation - Property
        Width - Property
IAcadMText (New/Renamed from IAcadMtext)
        Width - Property
        Height - Property
        Rotation - Property
        Normal - Property
        LineSpacingFactor - Property
        LineSpacingStyle - Property
IAcadPoint (Changed)
        Normal - Property
IAcadLWPolyline (Changed)
        Area - Property
        Closed - Property
        Normal - Property
        AddVertex - Method
        Explode - Method
        GetBulge - Method
        SetBulge - Method
        GetWidth - Method
        SetWidth - Method
        Offset - Method
        ConstantWidth - Property (New)
        Elevation - Property (New)
        LinetypeGeneration - Property (New)
IAcadPolyline (Changed)
        Area - Property
        Closed - Property
        Normal - Property
        Type - Property
        Explode - Method
        GetBulge - Method
        SetBulge - Method
        GetWidth - Method
        SetWidth - Method
        Offset - Method
IAcadRay (Changed)
        BasePoint - Property
        DirectionVector - Property
        SecondPoint - Property (New)
IAcadShape (Changed)
        Height - Property
        Name - Property
        Normal - Property
        Rotation - Property
IAcadSolid (Changed)
        Normal - Property
IAcadSpline (Changed)
        Area - Property
        Closed - Property
        Degree - Property
        EndTangent - Property
        FitTolerance - Property
        IsRational - Property
        NumberOfControlPoints - Property
        NumberOfFitPoints - Property
        StartTangent - Property
        SetControlPoint - Method
        GetControlPoint - Method
        SetFitPoint - Method
        GetFitPoint - Method
        SetWeight - Method
        GetWeight - Method
        AddFitPoint - Method
        DeleteFitPoint - Method
        ElevateOrder - Method
        Offset - Method
        PurgeFitData - Method
        Reverse - Method
        ControlPoints - Property (New)
        FitPoints - Property (New)
        IsPlanar - Property (New)
        IsPeriodic - Property (New)
        Knots - Property (New)
        Weights - Property (New)
IAcadText (Changed)
        Height - Property
        Normal - Property
        Rotation - Property
IAcadTolerance (Changed)
        Normal - Property
        TextColor - Property (New)
        TextStyle - Property (New)
        TextHeight - Property (New)
IAcadTrace (Changed)
        Normal - Property
IAcadXline (Change)
        Offset - Method
IAcadBlockReference (Changed)
        Name - Property
        Normal - Property
        Rotation - Property
        XScaleFactor - Property
        YScaleFactor - Property
        Explode - Method
        GetAttributes - Method
        HasAttributes - Property
        ZScaleFactor - Property
        GetConstantAttributes - Method (New)
IAcadHatch (Changed)
        Normal - Property
        AssociativeHatch - Property (Now Supports In/Out)
        NumberOfLoops - Property
        PatternType - Property
        PatternName - Property
        PatternAngle - Property
        PatternScale - Property
        PatternSpace - Property
        PatternDouble - Property
        HatchStyle - Property
        SetPattern - Method
        AppendOuterLoop - Method
        AppendInnerLoop - Method
        InsertLoopAt - Method
        GetLoopAt - Method
        Evaluate - Method
        ISOPenWidth - Property (New)
IAcadRaster (Removed)
        Handle - Property
        Color - Property
        Layer - Property
        Linetype - Property
        Visible - Property
        GetXData - Method
        SetXData - Method
        ArrayPolar - Method
        Highlight - Method
        Copy - Method
        Erase - Method
        Move - Method
        Rotate - Method
        Rotate3D - Method
        Mirror - Method
        Mirror3D - Method
        ScaleEntity- Method
        Update - Method
        ObjectID - Property
        ImageFile - Property
        Origin - Property
        ImageVisibility - Property
        ClippingEnabled - Property
        Transparency - Property
        Brightness - Property
        Contrast - Property
        Fade - Property
        ClipBoundary - Property
        Height - Property
        Width - Property
IAcadRasterImage (New/Renamed from IAcadRaster)
        Contrast - Property
        Fade - Property
        Origin - Property
        Rotation - Property
        ImageWidth - Property
        ImageHeight - Property
        Name - Property
        Height - Property
        Width - Property
        ShowRotation - Property
IAcadLine (Changed)
        EndPoint - Property
        Normal - Property
        Offset - Method
        Delta - Property (New)
IAcadLayout (New)
        Block - Property
        TabOrder - Property
IAcadPlotConfiguration (New)
        Name - Property
        ConfigName - Property
        CanonicalMediaName - Property
        PaperUnits - Property
        PlotViewportBorders - Property
        ShowPlotStyles - Property
        PlotRotation - Property
        CenterPlot - Property
        PlotHidden - Property
        PlotType - Property
        ViewToPlot - Property
        UseStandardScale - Property
        GetCustomScale - Method
        SetCustomScale - Method
        ScaleLineweights - Property
        PlotWithLineweights - Property
        PlotViewportsFirst - Property
        StyleSheet - Property
        GetPaperMargins - Method
        GetPaperSize - Method
        PlotOrigin - Property
        GetWindowToPlot - Method
        SetWindowToPlot - Method
        PlotWithPlotStyles - Property
        ModelType - Property
        CopyFrom - Method
        GetCanonicalMediaNames - Method
        GetPlotDeviceNames - Method
        GetPlotStyleTableNames - Method
        RefreshPlotDeviceInfo - Method
        GetLocaleMediaName - Method
IAcadMInsertBlock (New)
        Columns - Property
        ColumnSpacing - Property
        Rows - Property
        RowSpacing - Property
IAcadPolyfaceMesh (New)
        NumberOfVertices - Property
        NumberOfFaces - Property
        Faces - Method
IAcadMLine (New)
IAcadDim3PointAngular (New)
        AngleVertex - Property
        Fit - Property
IAcadExternalReference (New)
        Path - Property
IAcadPaperSpace (Changed)
        Count - Property (Removed)
        AddLine - Method (Removed)
        AddCustomObject - Method (Removed)
        Add3DFace - Method (Removed)
        Add3DMesh - Method (Removed)
        Add3DPoly - Method (Removed)
        AddArc - Method (Removed)
        AddAttribute - Method (Removed)
        AddBox - Method (Removed)
        AddCircle - Method (Removed)
        AddCone - Method (Removed)
        AddCylinder - Method (Removed)
        AddDimAligned - Method (Removed)
        AddDimAngular - Method (Removed)
        AddDimDiametric - Method (Removed)
        AddDimRotated - Method (Removed)
        AddDimOrdinate - Method (Removed)
        AddDimRadial - Method (Removed)
        AddEllipse - Method (Removed)
        AddEllipticalCone - Method (Removed)
        AddEllipticalCylinder - Method (Removed)
        AddExtrudedSolid - Method (Removed)
        AddExtrudedSolidAlongPath - Method (Removed)
        AddLeader - Method (Removed)
        AddMText - Method (Removed)
        AddPoint - Method (Removed)
        AddLightWeightPolyline - Method (Removed)
        AddPolyline - Method (Removed)
        AddRay - Method (Removed)
        AddRegion - Method (Removed)
        AddRevolvedSolid - Method (Removed)
        AddShape - Method (Removed)
        AddSolid - Method (Removed)
        AddSphere - Method (Removed)
        AddSpline - Method (Removed)
        AddText - Method (Removed)
        AddTolerance - Method (Removed)
        AddTorus - Method (Removed)
        AddTrace - Method (Removed)
        AddWedge - Method (Removed)
        AddXline - Method (Removed)
        InsertBlock - Method (Removed)
        AddHatch - Method (Removed)
        AddRaster - Method (Removed)
        AddPViewport - Method
IAcadPViewport (Changed)
        Center - Property
        GridOn - Property
        Height - Property
        Width - Property
        SnapBasePoint - Property
        SnapOn - Property
        SnapRotationAngle - Property
        UCSIconOn - Property
        UCSIconAtOrigin - Property
        GetGridSpacing - Method
        SetGridSpacing - Method
        GetSnapSpacing - Method
        SetSnapSpacing - Method
        Display - Property
        TwistAngle - Property
        LensLength - Property
        RemoveHiddenLines - Property
        Target - Property
        ZoomExtents - Method
        ZoomAll - Method
        ZoomCenter - Method
        ZoomScaled - Method
        ZoomWindow - Method
        ZoomPickWindow - Method
        ViewportOn - Property (New)
        Clipped - Property (New)
        DisplayLocked - Property (New)
        StandardScale - Property (New)
        CustomScale - Property (New)
        StyleSheet - Property (New)
        UCSPerViewport - Property (New)
        ArcSmoothness - Property (New)
IAcadBlocks (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadGroups (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadGroup (Changed)
        Item - Method
        Count - Property
        Color - Property
        Layer - Property
        Linetype - Property
        Visible - Property
        Highlight - Method
        Name - Property
        AppendItems - Method
        RemoveItems - Method
        Delete - Method (Removed)
        Update - Method
IAcadDimStyles (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadDimStyle (Changed)
        Name - Property
        CopyFrom - Method (New)
IAcadLayers (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadLayer (Changed)
        Color - Property
        Freeze - Property
        LayerOn - Property
        Linetype - Property
        Lock - Property
        Name - Property
        Delete - Method
        GetXData - Method
        SetXData - Method
        Handle - Property
        Plottable - Property (New)
        ViewportDefault - Property (New)
IAcadLineTypes (Changed)
        Item - Method
        Count - Property
        Add - Method
        Load - Method
IAcadLineType (Changed)
        Name - Property
        Handle - Method (Removed)
IAcadDictionaries (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadDictionary (Changed)
        Name - Property
        AddObject - Method
        GetName - Method
        GetObject - Method
        Remove - Method
        Rename - Method
        Replace - Method
        Item - Method (Removed)
        AddXRecord - Method (Removed)
IAcadXRecord (New)
        Name - Property
        GetXRecordData - Method
        SetXRecordData - Method
        TranslateIDs - Property
IAcadRegisteredApplications (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadRegisteredApplication (Changed)
        Name - Property
IAcadTextStyles (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadTextStyle (Changed)
        BigFontFile - Property
        FontFile - Property
        Height - Property
        LastHeight - Property
        Name - Property
        Width - Property
        GetFont - Method
        SetFont - Method
IAcadUCSs (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadUCS (Changed)
        Name - Property
        Origin - Property
        XVector - Property
        YVector - Property
        GetUCSMatrix - Method
IAcadViews (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadView (Changed)
        Center - Property
        Height - Property
        Width - Property
        Target - Property
        Name - Property
IAcadViewports (Changed)
        Item - Method
        Count - Property
        Add - Method
        DeleteConfiguration - Method (New)
IAcadViewport (Changed)
        Center - Property
        Height - Property
        Width - Property
        Target - Property
        Name - Property
        GridOn - Property
        OrthoOn - Property
        SnapOn - Property
        StatusId - Property (Removed)
        LowerLeftCorner - Property
        UpperRightCorner - Property
        Split - Method
        SetView - Method
        ZoomExtents - Method (Removed)
        ZoomAll - Method (Removed)
        ZoomCenter - Method (Removed)
        ZoomScaled - Method (Removed)
        ZoomWindow - Method (Removed)
        ZoomPickWindow - Method (Removed)
IAcadLayouts (New)
        Item - Method
        Count - Property
        Add - Method
IAcadPlotConfigurations (New)
        Item - Method
        Count - Property
        Add - Method
IAcadDatabasePreferences (New)
        SolidFill - Property
        XRefEdit - Property
        XRefLayerVisibility - Property
        OLELaunch - Property
        AllowLongSymbolNames - Property
        ObjectSortBySelection - Property
        ObjectSortBySnap - Property
        ObjectSortByRedraws - Property
        ObjectSortByRegens - Property
        ObjectSortByPlotting - Property
        ObjectSortByPSOutput - Property
        ContourLinesPerSurface - Property
        DisplaySilhouette - Property
        MaxActiveViewports - Property
        RenderSmoothness - Property
        SegmentPerPolyline - Property
        TextFrameDisplay - Property
        LineWeightDisplay - Property
IAcadObjectEvents (New)
        Modified - Event
IAcadIdPair (New)
        IsCloned - Property
        IsOwnerXlated - Property
        IsPrimary - Property
        Key - Property
        Value - Property
_DAcadApplicationEvents (New)
        SysVarChanged - Event
        NewDrawing - Event
        AppActivate - Event
        AppDeactivate - Event
        WindowMovedOrResized - Event
        BeginModal - Event
        EndModal - Event
        BeginQuit - Event
        BeginFileDrop - Event
        ARXLoaded - Event
        ARXUnloaded - Event
        BeginPlot - Event
        EndPlot - Event
        BeginSave - Event
        EndSave - Event
        BeginOpen - Event
        EndOpen - Event
        BeginCommand - Event
        EndCommand - Event
        BeginLisp - Event
        EndLisp - Event
        LispCancelled - Event
        WindowChanged - Event
IAcadDocument (Changed)
        Blocks - Property
        Plot - Property
        ActiveLayer - Property
        ActiveLinetype - Property
        ActiveDimStyle - Property
        ActiveTextStyle - Property
        ActiveUCS - Property
        ActiveViewport - Property
        ActivePViewport - Property
        ActiveSpace - Property
        SelectionSets - Property
        Groups - Property
        DimStyles - Property]
        Layers - Property
        Views - Property
        ActiveSelectionSet - Property
        FullName - Property
        Name - Property
        Path - Property
        Limits - Property
        ObjectSnapMode - Property
        ReadOnly - Property
        Saved - Property
        MSpace - Property
        Open - Method
        AuditInfo - Method
        Import - Method
        Export - Method
        New - Method
        Regen - Method
        Save - Method
        SaveAs - Method
        PurgeAll - Method
        GetVariable - Method
        SetVariable - Method
        LoadShapeFile - Method
        Wblock - Method
        Utility - Property
IAcadPlot (Changed)
        PlotOrientation - Property (Removed)
        PlotScale - Property (Removed)
        Rotation - Property (Removed)
        HideLines - Property (Removed)
        Origin - Property (Removed)
        PaperSize - Property (Removed)
        PlotUnits - Property (Removed)
        AdjustAreaFill - Property (Removed)
        PlotWithConfigFile - Property (Removed)
        PlotExtents - Method (Removed)
        PlotLimits - Method (Removed)
        PlotPreview - Method (Removed)
        PlotToFile - Method
        PlotToDevice - Method
        PlotView - Method (Removed)
        PlotWindow - Method (Removed)
        LoadPC2 - Method (Removed)
        SavePC2 - Method (Removed)
        QuietErrorMode - Property (New)
        NumberOfCopies - Property (New)
        BatchPlotProgress - Property (New)
        DisplayPlotPreview - Property (New)
        SetLayoutsToPlot - Method (New)
        StartBatchMode - Method (New)
IAcadApplication (Changed)
        Visible - Property
        Quit - Method
        Name - Property
        ActiveDocument - Property
        Caption - Property
        FullName - Property
        Height - Property
        Left - Property (Removed)
        Path - Property
        Top - Property (Removed)
        Version - Property
        Width - Property
        LocaleId - Property
        ListAds - Method (Removed)
        ListArx - Method
        LoadAds - Method (Removed)
        LoadArx - Method
        GetInterfaceObject - Method
        UnloadAds - Method (Removed)
        UnloadArx - Method
        Update - Method
        StartUndoMark - Method
        EndUndoMark - Method
        WindowLeft - Property (New)
        WindowTop - Property (New)
        StatusId - Property (New)
        VBE - Property (New)
        MenuGroups - Property (New)
        MenuBar - Property (New)
        LoadDVB - Method (New)
        UnloadDVB - Method (New)
        Documents - Property (New)
        Eval - Method (New)
        WindowState - Property (New)
        RunMacro - Method (New)
        ZoomExtents - Method (New)
        ZoomAll - Method (New)
        ZoomCenter - Method (New)
        ZoomScaled - Method (New)
        ZoomWindow - Method (New)
        ZoomPickWindow - Method (New)
        GetAcadState - Method (New)
        ZoomPrevious - Method (New)
IAcadPreferences (Changed)
        SupportPath - Property (Removed)
        DriversPath - Property (Removed)
        MenuFile - Property (Removed)
        AltTabletMenuFile - Property (Removed)
        HelpFilePath - Property (Removed)
        AutoSaveFile - Property (Removed)
        LogFileName - Property (Removed)
        DefaultInternetURL - Property (Removed)
        LicenseServer - Property (Removed)
        TextEditor - Property (Removed)
        MainDictionary - Property (Removed)
        CustomDictionary - Property (Removed)
        AltFontFile - Property (Removed)
        FontFileMap - Property (Removed)
        PrintFile - Property (Removed)
        PrintSpoolExecutable - Property (Removed)
        PostScriptPrologFile - Property (Removed)
        PrintSpoolerPath - Property (Removed)
        TemplateDwgPath - Property (Removed)
        TempFilePath - Property (Removed)
        TempXrefPath - Property (Removed)
        XrefDemandLoad - Property (Removed)
        TextFrameDisplay - Property (Removed)
        DisplaySilhouette - Property (Removed)
        RenderSmoothness - Property (Removed)
        ContourLinesPerSurface - Property (Removed)
        SegmentPerPolyline - Property (Removed)
        MaxActiveViewports - Property (Removed)
        IncrementalSavePercent - Property (Removed)
        PersistentLisp - Property (Removed)
        EnableStartupDialog - Property (Removed)
        ShowRasterImage - Property (Removed)
        KeyboardAccelerator - Property (Removed)
        FullCRCValidation - Property (Removed)
        AutoAudit - Property (Removed)
        LogFileOn - Property (Removed)
        SavePreviewThumbnail - Property (Removed)
        AutoSaveInterval - Property (Removed)
        CreateBackup - Property (Removed)
        BeepOnError - Property (Removed)
        MaxNumOfSymbols - Property (Removed)
        DisplayScreenMenu - Property (Removed)
        DisplayScrollBars - Property (Removed)
        MaxAutoCADWindow - Property (Removed)
        DockedVisibleLines - Property (Removed)
        HistoryLines - Property (Removed)
        GraphicsWinBackgrndColor - Property (Removed)
        GraphicsTextBackgrndColor - Property (Removed)
        GraphicsTextColor - Property (Removed)
        TextWinBackgrndColor - Property (Removed)
        TextWinTextColor - Property (Removed)
        CrosshairColor - Property (Removed)
        MonochromeVectors - Property (Removed)
        GraphicFont - Property (Removed)
        GraphicFontStyle - Property (Removed)
        GraphicFontSize - Property (Removed)
        TextFont - Property (Removed)
        TextFontStyle - Property (Removed)
        TextFontSize - Property (Removed)
        SetProjectFilePath - Method (Removed)
        GetProjectFilePath - Method (Removed)
        ImportProfile - Method (Removed)
        ExportProfile - Method (Removed)
        DeleteProfile - Method (Removed)
        ResetProfile - Method (Removed)
        ArcSmoothness - Property (Removed)
        CursorSize - Property (Removed)
        MeasurementUnits - Property (Removed)
        DemandLoadARXApp - Property (Removed)
        DisplayDraggedObject - Property (Removed)
        TextureMapPath - Property (Removed)
        ActiveProfile - Property (Removed)
        ProxyImage - Property (Removed)
        ShowProxyDialogBox - Property (Removed)
        KeyboardPriority - Property (Removed)
        TempFileExtension - Property (Removed)
        Files - Property (New)
        Display - Property (New)
        OpenSave - Property (New)
        Output - Property (New)
        System - Property (New)
        User - Property (New)
        Drafting - Property (New)
        Selection - Property (New)
        Profiles - Property (New)
IAcadPreferencesFiles (New)
        MenuFile - Property
        AutoSavePath - Property
        LogFilePath - Property
        PrinterConfigPath - Property
        PrinterDescPath - Property
        PrinterStyleSheetPath - Property
        WorkspacePath - Property
        ObjectARXPath - Property
IAcadPreferencesDisplay (New)
        LayoutDisplayMargins - Property
        LayoutDisplayPaper - Property
        LayoutDisplayPaperShadow - Property
        LayoutShowPlotSetup - Property
        LayoutCreateViewport - Property
        GraphicsWinModelBackgrndColor - Property
        ModelCrosshairColor - Property
        GraphicsWinLayoutBackgrndColor - Property
        LayoutCrosshairColor - Property
        AutoTrackingVecColor - Property
        TextFont - Property
        DisplayLayoutTabs - Property
        ImageFrameHighlight - Property
        TrueColorImages - Property
        XRefFadeIntensity - Property
IAcadPreferencesOpenSave (New)
        SaveAsType - Property
        MRUNumber - Property
IAcadPreferencesOutput (New)
        DefaultOutputDevice - Property
        PrinterSpoolAlert - Property
        PrinterPaperSizeAlert - Property
        PlotLegacy - Property
        OLEQuality - Property
        UseLastPlotSettings - Property
        PlotPolicy - Property
        DefaultPlotStyleTable - Property
        DefaultPlotStyleForObjects - Property
        DefaultPlotStyleForLayer - Property
IAcadPreferencesSystem (New)
        SingleDocumentMode - Property
        DisplayOLEScale - Property
        StoreSQLIndex - Property
        TablesReadOnly - Property
        ShowWarningMessages - Property
        LoadAcadLspInAllDocuments - Property
IAcadPreferencesUser (New)
        HyperlinkDisplayCursor - Property
        HyperlinkDisplayTooltip - Property
        ADCInsertUnitsDefaultSource( - Property
        ADCInsertUnitsDefaultTarget - Property
        ShortCutMenuDisplay - Property
        SCMDefaultMode - Property
        SCMEditMode - Property
        SCMCommandMode - Property
IAcadPreferencesDrafting (New)
        AutoSnapMarker - Property
        AutoSnapMagnet - Property
        AutoSnapTooltip - Property
        AutoSnapAperture - Property
        AutoSnapApertureSize - Property
        AutoSnapMarkerColor - Property
        AutoSnapMarkerSize - Property
        PolarTrackingVector - Property
        FullScreenTrackingVector - Property
        AutoTrackTooltip - Property
        AlignmentPointAcquisition - Property
IAcadPreferencesSelection (New)
        PickFirst - Property
        PickAdd - Property
        PickDrag - Property
        PickAuto - Property
        PickBoxSize - Property
        DisplayGrips - Property
        DisplayGripsWithinBlocks - Property
        GripColorSelected - Property
        GripColorUnselected - Property
        GripSize - Property
        PickGroup - Property
IAcadPreferencesProfiles (New)
        RenameProfile - Method
        CopyProfile - Method
        GetAllProfileNames - Method
IAcadMenuGroups (New)
        Item - Method
        Count - Property
        Parent - Property
        Load - Method
IAcadMenuGroup (New)
        Parent - Property
        Name - Property
        Type - Property
        MenuFileName - Property
        Menus - Property
        Toolbars - Property
        Unload - Method
        Save - Method
        SaveAs - Method
IAcadPopupMenus (New)
        Item - Method
        Count - Property
        Parent - Property
        Add - Method
        InsertMenuInMenuBar - Method
        RemoveMenuFromMenuBar - Method
IAcadPopupMenu (New)
        Item - Method
        Count - Property
        Parent - Property
        Name - Property
        NameNoMnemonic - Property
        ShortcutMenu - Property
        OnMenuBar - Property
        AddMenuItem - Method
        AddSubMenu - Method
        AddSeparator - Method
        InsertInMenuBar - Method
        RemoveFromMenuBar - Method
IAcadPopupMenuItem (New)
        Parent - Property
        Label - Property
        Enable - Property
        Check - Property
        Type - Property
        SubMenu - Property
        Macro - Property
        Index - Property
        Caption - Property
        HelpString - Property
        Delete - Method
        EndSubMenuLevel - Property
IAcadToolbars (New)
        Item - Method
        Count - Property
        Parent - Property
        LargeButtons - Property
        Add - Method
IAcadToolbar (New)
        Item - Method
        Count - Property
        Parent - Property
        Name - Property
        Visible - Property
        DockStatus - Property
        left - Property
        top - Property
        Width - Property
        Height - Property
        FloatingRows - Property
        AddToolbarButton - Method
        Dock - Method
        Float - Method
        Delete - Method
IAcadToolbarItem (New)
        Parent - Property
        Name - Property
        Type - Property
        Flyout - Property
        Macro - Property
        Index - Property
        GetBitmaps - Method
        SetBitmaps - Method
        AttachToolbarToFlyout - Method
        Delete - Method
IAcadMenuBar (New)
        Item - Method
        Count - Property
        Parent - Property
IAcadDocuments (New)
        Item - Method
        Count - Property
        Add - Method
        Open - Method
        Close - Method
IAcadState (New)
        IsQuiescent - Property
IAcadSelectionSets (Changed)
        Item - Method
        Count - Property
        Add - Method
IAcadSelectionSet
        Item - Method
        Count - Property
        Name - Property
        Highlight - Method
        Erase - Method
        Update - Method
        AddItems - Method
        Clear - Method
        Select - Method
        SelectAtPoint - Method
        SelectByPolygon - Method
        SelectOnScreen - Method
        Delete - Method
IAcadUtility (Changed)
        AngleToReal - Method
        AngleToString - Method
        DistanceToReal - Method
        RealToString - Method
        TranslateCoordinates - Method
        InitializeUserInput - Method
        GetInteger - Method
        GetReal - Method
        GetInput - Method
        GetKeyword - Method
        GetString - Method
        GetAngle - Method
        AngleFromXAxis - Method
        GetCorner - Method
        GetDistance - Method
        GetOrientation - Method
        GetPoint - Method
        PolarPoint - Method
        CreateTypedArray - Method
        GetEntity - Method
        Prompt - Method (New)
        GetSubEntity - Method (New)
        IsURL - Method (New)
        GetRemoteFile - Method (New)
        PutRemoteFile - Method (New)
        IsRemoteFile - Method (New)
        LaunchBrowserDialog - Method (New)
_DAcadDocumentEvents (Changed)
        BeginSave - Event
        EndSave - Event
        BeginOpen - Event (Removed)
        EndOpen - Event (Removed)
        BeginQuit - Event (Removed)
        EndCommand - Event
        BeginLisp - Event (New)
        EndLisp - Event (New)
        LispCancelled - Event (New)
        SelectionChanged - Event (New)
        Activate - Event (New)
        Deactivate - Event (New)
        BeginRightClick - Event (New)
        BeginShortcutMenuDefault - Event (New)
        BeginShortcutMenuEdit - Event (New)
        BeginShortcutMenuCommand - Event (New)
        BeginShortcutMenuGrip - Event (New)
        BeginShortcutMenuOsnap - Event (New)
        EndShortcutMenu - Event (New)
        BeginDoubleClick - Event (New)
        ObjectAdded - Event (New)
        ObjectErased - Event (New)
        ObjectModified - Event (New)
        BeginPlot - Event (New)
        EndPlot - Event (New)
        WindowMovedOrResized - Event (New)
        LayoutSwitched - Event (New)
        WindowChanged - Event (New)
        BeginClose - Event (New)
GMT+8, 2026-11-14 14:10
