AutoCAD 2005 API 历史记录参考 (ActiveX)
2024-5-18 18:19| 发布者: admin| 查看: 965| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2005 和基于 AutoCAD 2005 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcEntityName (Changed)
        acTable = 43 (New)
AcTableDirection (New)
        acTableTopToBottom = 0
        acTableBottomToTop = 1
AcCellAlignment (New)
        acTopLeft = 1
        acTopCenter = 2
        acTopRight = 3
        acMiddleLeft = 4
        acMiddleCenter = 5
        acMiddleRight = 6
        acBottomLeft = 7
        acBottomCenter = 8
        acBottomRight = 9
AcRowType (New)
        acUnknownRow = 0
        acDataRow = 1
        acTitleRow = 2
        acHeaderRow = 4
AcGridLineType (New)
        acInvalidGridLine = 0
        acHorzTop = 1
        acHorzInside = 2
        acHorzBottom = 4
        acVertLeft = 8
        acVertInside = 16
        acVertRight = 32
AcCellType (New)
        acUnknownCell = 0
        acTextCell = 1
        acBlockCell = 2
AcCellEdgeMask (New)
        acTopMask = 1
        acRightMask = 2
        acBottomMask = 4
        acLeftMask = 8
AcRotationAngle (New)
        acDegreesUnknown = 0xffffffff
        acDegrees000 = 0
        acDegrees090 = 1
        acDegrees180 = 2
        acDegrees270 = 3
AcSelectType (New)
        acTableSelectWindow = 1
        acTableSelectCrossing = 2
AcOleType (New)
        acOTLink = 1
        acOTEmbedded = 2
        acOTStatic = 3
AcOlePlotQuality (New)
        acOPQMonochrome = 0
        acOPQLowGraphics = 1
        acOPQHighGraphics = 2
AcTableStyleOverrides (New)
        acTitleSuppressed = 1
        acHeaderSuppressed = 2
        acFlowDirection = 3
        acHorzCellMargin = 4
        acVertCellMargin = 5
        acTitleRowColor = 6
        acHeaderRowColor = 7
        acDataRowColor = 8
        acTitleRowFillNone = 9
        acHeaderRowFillNone = 10
        acDataRowFillNone = 11
        acTitleRowFillColor = 12
        acHeaderRowFillColor = 13
        acDataRowFillColor = 14
        acTitleRowAlignment = 15
        acHeaderRowAlignment = 16
        acDataRowAlignment = 17
        acTitleRowTextStyle = 18
        acHeaderRowTextStyle = 19
        acDataRowTextStyle = 20
        acTitleRowTextHeight = 21
        acHeaderRowTextHeight = 22
        acDataRowTextHeight = 23
        acTitleHorzTopColor = 40
        acTitleHorzInsideColor = 41
        acTitleHorzBottomColor = 42
        acTitleVertLeftColor = 43
        acTitleVertInsideColor = 44
        acTitleVertRightColor = 45
        acHeaderHorzTopColor = 46
        acHeaderHorzInsideColor = 47
        acHeaderHorzBottomColor = 48
        acHeaderVertLeftColor = 49
        acHeaderVertInsideColor = 50
        acHeaderVertRightColor = 51
        acDataHorzTopColor = 52
        acDataHorzInsideColor = 53
        acDataHorzBottomColor = 54
        acDataVertLeftColor = 55
        acDataVertInsideColor = 56
        acDataVertRightColor = 57
        acTitleHorzTopLineWeight = 70
        acTitleHorzInsideLineWeight = 71
        acTitleHorzBottomLineWeight = 72
        acTitleVertLeftLineWeight = 73
        acTitleVertInsideLineWeight = 74
        acTitleVertRightLineWeight = 75
        acHeaderHorzTopLineWeight = 76
        acHeaderHorzInsideLineWeight = 77
        acHeaderHorzBottomLineWeight = 78
        acHeaderVertLeftLineWeight = 79
        acHeaderVertInsideLineWeight = 80
        acHeaderVertRightLineWeight = 81
        acDataHorzTopLineWeight = 82
        acDataHorzInsideLineWeight = 83
        acDataHorzBottomLineWeight = 84
        acDataVertLeftLineWeight = 85
        acDataVertInsideLineWeight = 86
        acDataVertRightLineWeight = 87
        acTitleHorzTopVisibility = 100
        acTitleHorzInsideVisibility = 101
        acTitleHorzBottomVisibility = 102
        acTitleVertLeftVisibility = 103
        acTitleVertInsideVisibility = 104
        acTitleVertRightVisibility = 105
        acHeaderHorzTopVisibility = 106
        acHeaderHorzInsideVisibility = 107
        acHeaderHorzBottomVisibility = 108
        acHeaderVertLeftVisibility = 109
        acHeaderVertInsideVisibility = 110
        acHeaderVertRightVisibility = 111
        acDataHorzTopVisibility = 112
        acDataHorzInsideVisibility = 113
        acDataHorzBottomVisibility = 114
        acDataVertLeftVisibility = 115
        acDataVertInsideVisibility = 116
        acDataVertRightVisibility = 117
        acCellAlign = 130
        acCellBackgroundFillNone = 131
        acCellBackgroundColor = 132
        acCellContentColor = 133
        acCellTextStyle = 134
        acCellTextHeight = 135
        acCellTopGridColor = 136
        acCellRightGridColor = 137
        acCellBottomGridColor = 138
        acCellLeftGridColor = 139
        acCellTopGridLineWeight = 140
        acCellRightGridLineWeight = 141
        acCellBottomGridLineWeight = 142
        acCellLeftGridLineWeight = 143
        acCellTopVisibility = 144
        acCellRightVisibility = 145
        acCellBottomVisibility = 146
        acCellLeftVisibility = 147
类
IAcadSortentsTable (New)
        MoveToBottom - Method
        MoveToTop - Method
        MoveBelow - Method
        MoveAbove - Method
        SwapOrder - Method
        Block - Method
        GetFullDrawOrder - Method
        GetRelativeDrawOrder - Method
        SetRelativeDrawOrder - Method
IAcadLayer2 (New)
        Description - Property
        Used - Property
IAcadView2 (New)
        CategoryName - Property
        LayoutId - Property
        LayerState - Property
        HasVpAssociation - Property
IAcadTableStyle (New)
        Name - Property
        BitFlags - Property
        FlowDirection - Property
        HorzCellMargin - Property
        VertCellMargin - Property
        TitleSuppressed - Property
        HeaderSuppressed - Property
        GetTextStyle - Method
        SetTextStyle - Method
        GetTextHeight - Method
        SetTextHeight - Method
        GetAlignment - Method
        SetAlignment - Method
        GetColor - Method
        SetColor - Method
        GetBackgroundColor - Method
        SetBackgroundColor - Method
        GetBackgroundColorNone - Method
        SetBackgroundColorNone - Method
        GetGridLineWeight - Method
        SetGridLineWeight - Method
        GetGridColor - Method
        SetGridColor - Method
        GetGridVisibility - Method
        SetGridVisibility - Method
IAcadLayers2 (New)
        GenerateUsageData - Method
IAcadMText2 (New)
        BackgroundFill - Property
        FieldCode - Method
IAcadText2 (New)
        FieldCode - Method
IAcadPViewport2 (New)
        ModelView - Property
        SheetView - Property
        LabelBlockId - Property
        HasSheetView - Property
        SyncModelView - Method
IAcadTable (New)
        StyleName - Property
        Rows - Property
        Columns - Property
        Width - Property
        Height - Property
        InsertionPoint - Property
        GetColumnWidth - Method
        SetColumnWidth - Method
        GetRowHeight - Method
        SetRowHeight - Method
        RowHeight - Method
        GetMinimumColumnWidth - Method
        GetMinimumRowHeight - Method
        MinimumTableWidth - Property
        MinimumTableHeight - Property
        GetContentColor - Method
        SetContentColor - Method
        TableStyleOverrides - Property
        ClearTableStyleOverrides - Method
        GetCellType - Method
        SetCellType - Method
        GetCellExtents - Method
        GetAttachmentPoint - Method
        GetCellAlignment - Method
        SetCellAlignment - Method
        GetCellBackgroundColorNone - Method
        SetCellBackgroundColorNone - Method
        GetCellBackgroundColor - Method
        SetCellBackgroundColor - Method
        GetCellContentColor - Method
        SetCellContentColor - Method
        GetCellStyleOverrides - Method
        DeleteCellContent - Method
        GetRowType - Method
        GetText - Method
        SetText - Method
        GetCellTextStyle - Method
        SetCellTextStyle - Method
        GetCellTextHeight - Method
        SetCellTextHeight - Method
        GetTextRotation - Method
        SetTextRotation - Method
        GetAutoScale - Method
        SetAutoScale - Method
        GetBlockTableRecordId - Method
        SetBlockTableRecordId - Method
        GetBlockScale - Method
        SetBlockScale - Method
        GetBlockRotation - Method
        SetBlockRotation - Method
        GetBlockAttributeValue - Method
        SetBlockAttributeValue - Method
        GetCellGridLineWeight - Method
        SetCellGridLineWeight - Method
        GetCellGridColor - Method
        SetCellGridColor - Method
        GetCellGridVisibility - Method
        SetCellGridVisibility - Method
        InsertColumns - Method
        DeleteColumns - Method
        InsertRows - Method
        DeleteRows - Method
        MergeCells - Method
        UnmergeCells - Method
        IsMergedCell - Method
        GetFieldId - Method
        SetFieldId - Method
        GenerateLayout - Method
        RecomputeTableBlock - Method
        HitTest - Method
        Select - Method
        SelectSubRegion - Method
        ReselectSubRegion - Method
        GetSubSelection - Method
        SetSubSelection - Method
        ClearSubSelection - Method
        HasSubSelection - Property
IAcadOle (New)
        Rotation - Property
        Width - Property
        Height - Property
        ScaleWidth - Property
        ScaleHeight - Property
        LockAspectRatio - Property
        OleItemType - Property
        OlePlotQuality - Property
        OleSourceApp - Property
IAcadBlock2 (New)
        AddTable - Method
        Path - Property
IAcadModelSpace2 (New)
        AddTable - Method
IAcadPaperSpace2 (New)
        AddTable - Method
_DAcadApplicationEvents (Changed)
        BeginFileDrop - Event (Changed the last parameter to accept and return a value)
IAcadPreferencesFiles2 (New)
        QNewTemplateFile - Property (New)
        PlotLogFilePath - Property (New)
        PageSetupOverridesTemplateFile - Property (New)
IAcadPreferencesOutput2 (New)
        ContinuousPlotLog - Property (New)
        AutomaticPlotLog - Property (New)
        DefaultPlotToFilePath - Property (New)
_DAcadDocumentEvents (Changed)
        BeginDocClose - Event (New)
GMT+8, 2026-11-14 18:28
