AutoCAD 2010 API 历史记录参考 (ActiveX)
对 AutoCAD 2010 和基于 AutoCAD 2010 的产品中的 ActiveX API 所做的添加和更改。 枚举AcEntityName (Changed)
acSubDMesh = 49 (New)
acPdfUnderlay = 50 (New)
AcPlotScale (Changed)
ac1_8 = 19 (Removed)
ac1_10 = 20 (Removed)
ac1_16 = 21 (Removed)
ac1_20 = 22 (Removed)
ac1_30 = 23 (Removed)
ac1_40 = 24 (Removed)
ac1_50 = 25 (Removed)
ac1_100 = 26 (Removed)
ac2_1 = 27 (Removed)
ac4_1 = 28 (Removed)
ac8_1 = 29 (Removed)
ac10_1 = 30 (Removed)
ac100_1 = 31 (Removed)
ac1_5 = 19 (New)
ac1_8 = 20 (New)
ac1_10 = 21 (New)
ac1_16 = 22 (New)
ac1_20 = 23 (New)
ac1_30 = 24 (New)
ac1_40 = 25 (New)
ac1_50 = 26 (New)
ac1_100 = 27 (New)
ac2_1 = 28 (New)
ac4_1 = 29 (New)
ac8_1 = 30 (New)
ac10_1 = 31 (New)
ac100_1 = 32 (New)
AcDimVerticalJustification (Changed)
acUnder = 4 (New)
AcViewportScale (Changed)
acVp1 = 2 (Removed)
acVp2 = 3 (Removed)
acVp3 = 4 (Removed)
acVp4 = 5 (Removed)
acVp5 = 6 (Removed)
acVp6 = 7 (Removed)
acVp7 = 8 (Removed)
acVp8 = 9 (Removed)
acVp9 = 10 (Removed)
acVp10 = 11 (Removed)
acVp11 = 12 (Removed)
acVp12 = 13 (Removed)
acVp13 = 14 (Removed)
acVp14 = 15 (Removed)
acVp15 = 16 (Removed)
acVp16 = 17 (Removed)
acVp17 = 18 (Removed)
acVp18 = 19 (Removed)
acVp19 = 20 (Removed)
acVp20 = 21 (Removed)
acVp21 = 22 (Removed)
acVp22 = 23 (Removed)
acVp23 = 24 (Removed)
acVp24 = 25 (Removed)
acVp25 = 26 (Removed)
acVp26 = 27 (Removed)
acVp27 = 28 (Removed)
acVp28 = 29 (Removed)
acVp29 = 30 (Removed)
acVp30 = 31 (Removed)
acVp31 = 32 (Removed)
acVp32 = 33 (Removed)
acVp33 = 34 (Removed)
acVp34 = 35 (Removed)
acVp35 = 36 (Removed)
acVp36 = 37 (Removed)
acVp37 = 38 (Removed)
acVp38 = 39 (Removed)
acVp39 = 40 (Removed)
acVp40 = 41 (Removed)
acVp41 = 42 (Removed)
acVp42 = 43 (Removed)
acVp43 = 44 (Removed)
acVp44 = 45 (Removed)
acVp45 = 46 (Removed)
acVp46 = 47 (Removed)
acVp47 = 48 (Removed)
acVp48 = 49 (Removed)
acVp49 = 50 (Removed)
acVp50 = 51 (Removed)
acVp51 = 52 (Removed)
acVp52 = 53 (Removed)
acVp53 = 54 (Removed)
acVp54 = 55 (Removed)
acVp55 = 56 (Removed)
acVp56 = 57 (Removed)
acVp57 = 58 (Removed)
acVp58 = 59 (Removed)
acVp59 = 60 (Removed)
acVp60 = 61 (Removed)
acVp61 = 62 (Removed)
acVp62 = 63 (Removed)
acVp63 = 64 (Removed)
acVp64 = 65 (Removed)
acVp65 = 66 (Removed)
acVp66 = 67 (Removed)
acVp67 = 68 (Removed)
acVp68 = 69 (Removed)
acVp69 = 70 (Removed)
acVp70 = 71 (Removed)
acVp71 = 72 (Removed)
acVp72 = 73 (Removed)
acVp73 = 74 (Removed)
acVp74 = 75 (Removed)
acVp75 = 76 (Removed)
acVp76 = 77 (Removed)
acVp77 = 78 (Removed)
acVp78 = 79 (Removed)
acVp79 = 80 (Removed)
acVp80 = 81 (Removed)
acVp81 = 82 (Removed)
acVp82 = 83 (Removed)
acVp83 = 84 (Removed)
acVp84 = 85 (Removed)
acVp85 = 86 (Removed)
acVp86 = 87 (Removed)
acVp87 = 88 (Removed)
acVp88 = 89 (Removed)
acVp89 = 90 (Removed)
acVp90 = 91 (Removed)
acVp91 = 92 (Removed)
acVp92 = 93 (Removed)
acVp93 = 94 (Removed)
acVp94 = 95 (Removed)
acVp95 = 96 (Removed)
acVp96 = 97 (Removed)
acVp97 = 98 (Removed)
acVp98 = 99 (Removed)
acVp99 = 100 (Removed)
acVp100 = 101 (Removed)
acVp1_8 = 5 (Removed)
acVp1_10 = 6 (Removed)
acVp1_16 = 7 (Removed)
acVp1_20 = 8 (Removed)
acVp1_30 = 9 (Removed)
acVp1_40 = 10 (Removed)
acVp1_50 = 11 (Removed)
acVp1_100 = 12 (Removed)
acVp2_1 = 13 (Removed)
acVp4_1 = 14 (Removed)
acVp8_1 = 15 (Removed)
acVp10_1 = 16 (Removed)
acVp100_1 = 17 (Removed)
acVp1_128in_1ft = 18 (Removed)
acVp1_64in_1ft = 19 (Removed)
acVp1_32in_1ft = 20 (Removed)
acVp1_16in_1ft = 21 (Removed)
acVp3_32in_1ft = 22 (Removed)
acVp1_8in_1ft = 23 (Removed)
acVp3_16in_1ft = 24 (Removed)
acVp1_4in_1ft = 25 (Removed)
acVp3_8in_1ft = 26 (Removed)
acVp1_2in_1ft = 27 (Removed)
acVp3_4in_1ft = 28 (Removed)
acVp1in_1ft = 29 (Removed)
acVp1and1_2in_1ft = 30 (Removed)
acVp3in_1ft = 31 (Removed)
acVp6in_1ft = 32 (Removed)
acVp1ft_1ft = 33 (Removed)
acVp1_5 = 5 (New)
acVp1_8 = 6 (New)
acVp1_10 = 7 (New)
acVp1_16 = 8 (New)
acVp1_20 = 9 (New)
acVp1_30 = 10 (New)
acVp1_40 = 11 (New)
acVp1_50 = 12 (New)
acVp1_100 = 13 (New)
acVp2_1 = 14 (New)
acVp4_1 = 15 (New)
acVp8_1 = 16 (New)
acVp10_1 = 17 (New)
acVp100_1 = 18 (New)
acVp1_128in_1ft = 19 (New)
acVp1_64in_1ft = 20 (New)
acVp1_32in_1ft = 21 (New)
acVp1_16in_1ft = 22 (New)
acVp3_32in_1ft = 23 (New)
acVp1_8in_1ft = 24 (New)
acVp3_16in_1ft = 25 (New)
acVp1_4in_1ft = 26 (New)
acVp3_8in_1ft = 27 (New)
acVp1_2in_1ft = 28 (New)
acVp3_4in_1ft = 29 (New)
acVp1in_1ft = 30 (New)
acVp1and1_2in_1ft = 31 (New)
acVp3in_1ft = 32 (New)
acVp6in_1ft = 33 (New)
acVp1ft_1ft = 34 (New)
AcTextAttachmentDirection (New)
acAttachmentHorizontal = 0
acAttachmentVertical = 1
AcVerticalTextAttachmentType (New)
acAttachmentCenter = 0
acAttachmentLinedCenter = 1
AcMeshCreaseType (New)
acNoneCrease = 0
acAlwaysCrease = 1
acCreaseByLevel = 2
类IAcadBlock (Changed)
AddMLeader - Method (Moved from IAcadBlock2)
IAcadAttribute (Changed)
MTextAttribute - Property (Moved from IAcadAttribute2)
MTextAttributeContent - Property (Moved from IAcadAttribute2)
UpdateMTextAttribute - Method (Moved from IAcadAttribute2)
MTextBoundaryWidth - Property (Moved from IAcadAttribute2)
MTextDrawingDirection - Property (Moved from IAcadAttribute2)
IAcadDimAligned (Changed)
DimConstrForm - Property (New)
DimConstrReference - Property (New)
DimConstrName - Property (New)
DimConstrExpression - Property (New)
DimConstrValue - Property (New)
DimConstrDesc - Property (New)
SubUnitsSuffix - Property (New)
SubUnitsFactor - Property (New)
AltSubUnitsSuffix - Property (New)
AltSubUnitsFactor - Property (New)
IAcadDimension (Changed)
DimTxtDirection - Property (New)
IAcadDimAngular (Changed)
IAcadDimDiametric (Changed)
IAcadDimRotated (Changed)
IAcadDimOrdinate (Changed)
IAcadDimRadial (Changed)
IAcadDim3PointAngular (Changed)
IAcadTable (Changed)
IsEmpty - Method (Moved from IAcadTable2)
CreateContent - Method (Moved from IAcadTable2)
MoveContent - Method (Moved from IAcadTable2)
DeleteContent - Method (Moved from IAcadTable2)
GetValue - Method (Moved from IAcadTable2)
SetValue - Method (Moved from IAcadTable2)
SetValueFromText - Method (Moved from IAcadTable2)
GetDataFormat - Method (Moved from IAcadTable2)
SetDataFormat - Method (Moved from IAcadTable2)
GetTextString - Method (Moved from IAcadTable2)
SetTextString - Method (Moved from IAcadTable2)
GetFieldId2 - Method (Moved from IAcadTable2)
SetFieldId2 - Method (Moved from IAcadTable2)
GetBlockTableRecordId2 - Method (Moved from IAcadTable2)
SetBlockTableRecordId2 - Method (Moved from IAcadTable2)
GetBlockAttributeValue2 - Method (Moved from IAcadTable2)
SetBlockAttributeValue2 - Method (Moved from IAcadTable2)
GetCustomData - Method (Moved from IAcadTable2)
SetCustomData - Method (Moved from IAcadTable2)
GetCellStyle - Method (Moved from IAcadTable2)
SetCellStyle - Method (Moved from IAcadTable2)
GetContentColor2 - Method (Moved from IAcadTable2)
SetContentColor2 - Method (Moved from IAcadTable2)
GetDataType2 - Method (Moved from IAcadTable2)
SetDataType2 - Method (Moved from IAcadTable2)
GetTextStyle2 - Method (Moved from IAcadTable2)
SetTextStyle2 - Method (Moved from IAcadTable2)
GetTextHeight2 - Method (Moved from IAcadTable2)
SetTextHeight2 - Method (Moved from IAcadTable2)
GetRotation - Method (Moved from IAcadTable2)
SetRotation - Method (Moved from IAcadTable2)
GetAutoScale2 - Method (Moved from IAcadTable2)
SetAutoScale2 - Method (Moved from IAcadTable2)
GetScale - Method (Moved from IAcadTable2)
SetScale - Method (Moved from IAcadTable2)
RemoveAllOverrides - Method (Moved from IAcadTable2)
GetGridLineWeight2 - Method (Moved from IAcadTable2)
SetGridLineWeight2 - Method (Moved from IAcadTable2)
GetGridLinetype - Method (Moved from IAcadTable2)
SetGridLinetype - Method (Moved from IAcadTable2)
GetGridColor2 - Method (Moved from IAcadTable2)
SetGridColor2 - Method (Moved from IAcadTable2)
GetGridVisibility2 - Method (Moved from IAcadTable2)
SetGridVisibility2 - Method (Moved from IAcadTable2)
GetGridDoubleLineSpacing - Method (Moved from IAcadTable2)
SetGridDoubleLineSpacing - Method (Moved from IAcadTable2)
EnableBreak - Property (Moved from IAcadTable2)
GetBreakHeight - Method (Moved from IAcadTable2)
SetBreakHeight - Method (Moved from IAcadTable2)
GetContentType - Method (Moved from IAcadTable2)
GetMargin - Method (Moved from IAcadTable2)
SetMargin - Method (Moved from IAcadTable2)
GetContentLayout - Method (Moved from IAcadTable2)
SetContentLayout - Method (Moved from IAcadTable2)
GetOverride - Method (Moved from IAcadTable2)
SetOverride - Method (Moved from IAcadTable2)
GetGridLineStyle - Method (Moved from IAcadTable2)
SetGridLineStyle - Method (Moved from IAcadTable2)
InsertRowsAndInherit - Method (Moved from IAcadTable2)
InsertColumnsAndInherit - Method (Moved from IAcadTable2)
GetHasFormula - Method (Moved from IAcadTable2)
GetFormula - Method (Moved from IAcadTable2)
SetFormula - Method (Moved from IAcadTable2)
IsContentEditable - Method (Moved from IAcadTable2)
IsFormatEditable - Method (Moved from IAcadTable2)
GetCellState - Method (Moved from IAcadTable2)
SetCellState - Method (Moved from IAcadTable2)
EnableMergeAll - Method (Moved from IAcadTable2)
IsMergeAllEnabled - Method (Moved from IAcadTable2)
BreaksEnabled - Property (Moved from IAcadTable2)
RepeatTopLabels - Property (Moved from IAcadTable2)
RepeatBottomLabels - Property (Moved from IAcadTable2)
TableBreakFlowDirection - Property (Moved from IAcadTable2)
AllowManualPositions - Property (Moved from IAcadTable2)
AllowManualHeights - Property (Moved from IAcadTable2)
TableBreakHeight - Property (Moved from IAcadTable2)
BreakSpacing - Property (Moved from IAcadTable2)
GetColumnName - Method (Moved from IAcadTable2)
SetColumnName - Method (Moved from IAcadTable2)
SetToolTip - Method (Moved from IAcadTable2)
GetFieldId232 - Method (Moved from IAcadTable2)
SetFieldId232 - Method (Moved from IAcadTable2)
GetBlockTableRecordId232 - Method (Moved from IAcadTable2)
SetBlockTableRecordId232 - Method (Moved from IAcadTable2)
GetBlockAttributeValue232 - Method (Moved from IAcadTable2)
SetBlockAttributeValue232 - Method (Moved from IAcadTable2)
GetGridLinetype32 - Method (Moved from IAcadTable2)
SetGridLinetype32 - Method (Moved from IAcadTable2)
IAcadDimArcLength (Changed)
IAcadMLeader (Changed)
LeaderLinetype - Property (Renamed, previously LeaderLineType)
BlockScale - Property (New)
TextAttachmentDirection - Property (New)
TextTopAttachmentType - Property (New)
TextBottomAttachmentType - Property (New)
IAcadPViewport (Changed)
StandardScale2 - Property (New)
LayerPropertyOverrides - Property (Moved from IAcadPViewport2)
IAcadTableStyle (Changed)
CreateCellStyle - Method (Moved from IAcadTableStyle2)
CreateCellStyleFromStyle - Method (Moved from IAcadTableStyle2)
RenameCellStyle - Method (Moved from IAcadTableStyle2)
DeleteCellStyle - Method (Moved from IAcadTableStyle2)
GetUniqueCellStyleName - Method (Moved from IAcadTableStyle2)
GetIsCellStyleInUse - Method (Moved from IAcadTableStyle2)
NumCellStyles - Property (Moved from IAcadTableStyle2)
GetCellStyles - Method (Moved from IAcadTableStyle2)
GetTextStyleId - Method (Moved from IAcadTableStyle2)
SetTextStyleId - Method (Moved from IAcadTableStyle2)
GetTextHeight2 - Method (Moved from IAcadTableStyle2)
SetTextHeight2 - Method (Moved from IAcadTableStyle2)
GetAlignment2 - Method (Moved from IAcadTableStyle2)
SetAlignment2 - Method (Moved from IAcadTableStyle2)
GetColor2 - Method (Moved from IAcadTableStyle2)
SetColor2 - Method (Moved from IAcadTableStyle2)
GetBackgroundColor2 - Method (Moved from IAcadTableStyle2)
SetBackgroundColor2 - Method (Moved from IAcadTableStyle2)
GetDataType2 - Method (Moved from IAcadTableStyle2)
SetDataType2 - Method (Moved from IAcadTableStyle2)
GetFormat2 - Method (Moved from IAcadTableStyle2)
SetFormat2 - Method (Moved from IAcadTableStyle2)
GetCellClass - Method (Moved from IAcadTableStyle2)
SetCellClass - Method (Moved from IAcadTableStyle2)
GetRotation - Method (Moved from IAcadTableStyle2)
SetRotation - Method (Moved from IAcadTableStyle2)
GetIsMergeAllEnabled - Method (Moved from IAcadTableStyle2)
EnableMergeAll - Method (Moved from IAcadTableStyle2)
GetGridLineWeight2 - Method (Moved from IAcadTableStyle2)
SetGridLineWeight2 - Method (Moved from IAcadTableStyle2)
GetGridColor2 - Method (Moved from IAcadTableStyle2)
SetGridColor2 - Method (Moved from IAcadTableStyle2)
GetGridVisibility2 - Method (Moved from IAcadTableStyle2)
SetGridVisibility2 - Method (Moved from IAcadTableStyle2)
TemplateId - Property (Moved from IAcadTableStyle2)
SetTemplateId - Method (Moved from IAcadTableStyle2)
GetTextStyleId32 - Method (Moved from IAcadTableStyle2)
SetTextStyleId32 - Method (Moved from IAcadTableStyle2)
TemplateId32 - Property (Moved from IAcadTableStyle2)
SetTemplateId32 - Method (Moved from IAcadTableStyle2)
IAcadMLeaderStyle (Changed)
IAcadAttributeReference (Changed)
MTextAttribute - Property (Moved from IAcadAttributeReference2)
MTextAttributeContent - Property (Moved from IAcadAttributeReference2)
UpdateMTextAttribute - Method (Moved from IAcadAttributeReference2)
MTextBoundaryWidth - Property (Moved from IAcadAttributeReference2)
MTextDrawingDirection - Property (Moved from IAcadAttributeReference2)
IAcadMLeaderLeader (New)
LeaderType - Property
LeaderLineColor - Property
LeaderLineWeight - Property
ArrowheadType - Property
ArrowheadSize - Property
ArrowheadBlock - Property
IAcadUnderlay (Changed)
UnderlayLayerOverrideApplied - Property (Moved from IAcadUnderlay2)
IAcadDwfUnderlay (New)
DWFFormat - Property (Moved from IAcadUnderlay3)
IAcadSubDMesh (New)
Smoothness - Property
Coordinates - Property
Coordinate - Property
VertexCount - Property
FaceCount - Property
IAcadSubDMeshFace (New)
Material - Property
CreaseType - Property
CreaseLevel - Property
IAcadSubDMeshEdge (New)
IAcadSubDMeshVertex (New)
IAcadModelSpace (Changed)
AddMLeader - Method (Moved from IAcadModelSpace2)
IAcadPaperSpace (Changed)
AddMLeader - Method (Moved from IAcadPaperSpace2)
IAcadPreferencesUser (Changed)
HyperlinkDisplayTooltip - Property (Removed)
IAcadToolbarItem (Changed)
CommandDisplayName - Property (Moved from IAcadToolbarItem2)
IAcadUtility (Changed)
GetSubEntity32 - Method (Moved from IAcadUtility2)
ObjectId32ToObjectIdString - Method (Moved from IAcadUtility2)
GetObjectIdString - Method (Moved from IAcadUtility2)
以下类已删除/与其父类合并: IAcadTableStyle2 (Removed - Moved to IAcadTableStyle) IAcadAttribute2 (Removed - Moved to IAcadAttribute) IAcadAttributeReference2 (Removed - Moved to IAcadAttributeReference) IAcadPViewport2 (Removed - Moved to IAcadPViewport) IAcadTable2 (Removed - Moved to IAcadTable) IAcadUnderlay2 (Removed - Moved to IAcadUnderlay) IAcadUnderlay3 (Removed - Moved to IAcadUnderlay) IAcadBlock2 (Removed - Moved to IAcadBlock) IAcadModelSpace2 (Removed - Moved to IAcadModelSpace) IAcadPaperSpace2 (Removed - Moved to IAcadPaperSpace) IAcadUtility2 (Removed - Moved to IAcadUtility) IAcadToolbarItem2 (Removed - Moved to IAcadToolbarItem) 相关概念 |
GMT+8, 2026-11-12 12:24
