AutoCAD 2015 API 历史记录参考 (ActiveX)
2024-5-18 18:19| 发布者: admin| 查看: 903| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2015 和基于 AutoCAD 2015 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcPointCloudExStylizationType (New)
        acRGB = 0
        acObject = 1
        acNormals = 2
        acIntensities = 3
        acElevation = 4
        acClassification = 5
类
IAcadApplication
        HWND32 - Property (Removed; use HWND)
IAcadDatabase
        ObjectIDToObject32 - Method (Removed; use ObjectIDToObject)
IAcadDocument
        PostCommand - Method (New)
IAcadGeomapImage (New)
        GeoImageBrightness - Property
        GeoImageContrast - Property
        GeoImageFade - Property
        GeoImagePosition - Property
        GeoImageWidth - Property
        GeoImageHeight - Property
IAcadIDPair
        Key32 - Property (Removed; use Key)
        Value32 - Property (Removed; use Value)
IAcadMLeader
        GetBlockAttributeValue32 - Method (Removed; use GetBlockAttributeValue)
        SetBlockAttributeValue32 - Method (Removed; use SetBlockAttributeValue)
IAcadObject
        ObjectID32 - Property (Removed; use ObjectID)
        OwnerID32 - Property (Removed; use OwnerID)
IAcadPointCloud (Changed)
        Stylization - Property (Moved from IAcadPointCloud2)
        Unit - Property (Moved from IAcadPointCloud2)
        UnitFactor - Property (Moved from IAcadPointCloud2)
IAcadPointCloudEx (New)
        ColorScheme - Property
        Geolocate - Property
        InsertionPoint - Property
        Locked - Property
        Name - Property
        Path - Property
        Rotation - Property
        scale - Property
        ShowCropped - Property
        Unit - Property
IAcadPViewport
        LabelBlockId32 - Property (Removed; use LabelBlockId)
IAcadTable
        GetBlockAttributeValue232 - Method (Removed; use GetBlockAttributeValue2)
        GetBlockTableRecordId232 - Method (Removed; use GetBlockTableRecordId2)
        GetBlockTableRecordId32 - Method (Removed; use GetBlockTableRecordId)
        GetFieldId232 - Method (Removed; use GetFieldId2)
        GetFieldId32 - Method (Removed; use GetFieldId)
        GetGridLinetype32 - Method (Removed; use GetGridLinetype)
        SetBlockAttributeValue232 - Method (Removed; use SetBlockAttributeValue2)
        SetBlockTableRecordId232 - Method (Removed; use SetBlockTableRecordId2)
        SetBlockTableRecordId32 - Method (Removed; use SetBlockTableRecordId)
        SetFieldId232 - Method (Removed; use SetFieldId2)
        SetFieldId32 - Method (Removed; use SetFieldId)
        SetGridLinetype32 - Method (Removed; use SetGridLinetype)
IAcadTableStyle
        GetTextStyleId32 - Method (Removed; use GetTextStyleId)
        SetTemplateId32 - Method (Removed; use SetTemplateId)
        SetTextStyleId32 - Method (Removed; use SetTextStyleId)
        TemplateId32 - Property (Removed; use TemplateId)
IAcadUtility
        GetSubEntity32 - Method (Removed; use GetSubEntity)
        ObjectId32ToObjectIdString - Method (Removed; use ObjectIdToObjectIdString)
IAcadView
        LayoutID32 - Property (Removed; use LayoutID)
_DAcadDocumentEvents (Changed)
        ObjectErased - Event (ObjectID must now be a Long)
        WindowMovedOrResized - Event (HWNDFrame must now be a Long)
以下类已删除/与其父类合并:
IAcadPointCloud2 - Removed (Moved to IAcadPointCloud)
GMT+8, 2026-11-13 13:53
