AutoCAD 2017 API 历史记录参考 (ActiveX)
对 AutoCAD 2017 和基于 AutoCAD 2017 的产品中的 ActiveX API 所做的添加和更改。 枚举AcInsertUnits (Changed)
acInsertUnitsUSSurveyFeet = 21 (New)
acInsertUnitsUSSurveyInch = 22 (New)
acInsertUnitsUSSurveyYard = 23 (New)
acInsertUnitsUSSurveyMile = 24 (New)
类AcadAcCmColor
Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.AcCmColor.21.
AcadApplication
Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.Application.21.
ProgID AutoCAD.Application.20.1 is now obsolete.
AcadLayerStateManager
Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.AcadLayerStateManager.21.
AcadSecurityParams
Version number of the class has been incremented from 20 to 21; use the ProgID AutoCAD.SecurityParams.21.
IAcadShadowDisplay (Obsolete)
EnableShadowDisplay - Property (Obsolete)
相关概念 |
GMT+8, 2026-11-12 12:49
