AutoCAD 2019 API 历史记录参考 (ActiveX)
对 AutoCAD 2019 和基于 AutoCAD 2019 的产品中的 ActiveX API 所做的添加和更改。 类AcadAcCmColor
Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.AcCmColor.23
AcadApplication
Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.Application.23
AcadLayerStateManager
Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.AcadLayerStateManager.23
AcadSecurityParams
Version number of the class has been incremented from 22 to 23; use the ProgID AutoCAD.SecurityParams.23
IAcadExternalReference (Changed)
LayerPropertyOverrides - Property (New)
相关概念 |
GMT+8, 2026-11-15 15:19
