查看代码 (AutoLISP)
2024-5-18 18:19| 发布者: admin| 查看: 681| 评论: 0|原作者: admin|来自: AutoCAD
查看代码 (AutoLISP)
现在看一下该函数的代码:gp:calculate-Draw-TileRow
(defun gp:calculate-Draw-TileRow (startPoint TileRadius
                                  TileSpace pathWidth pathAngle
                                  offsetFromCenter ObjectCreationStyle /
                                  HalfWidth TileDiameter
                                  ObjectCreationFunction angp90 angm90
                                  firstCenterPt TileCenterPt TileList)
  (setq HalfWidth (- (/ pathWidth 2.00) TileRadius)
        Tilespacing (+ (* TileRadius 2.0) TileSpace)
        TileDiameter (* TileRadius 2.0)
        angp90 (+ PathAngle (Degrees->Radians 90))
        angm90 (- PathAngle (Degrees->Radians 90))
        firstCenterPt (polar startPoint angp90 offsetFromCenter)
        tileCenterPt firstCenterPt
        ObjectCreationStyle(strcase ObjectCreationStyle)
        (cond
          ((equal ObjectCreationStyle "ACTIVEX")
            gp:Create_activeX_Circle
          ((equal ObjectCreationStyle "ENTMAKE")
            gp:Create_entmake_Circle
          ((equal ObjectCreationStyle "COMMAND")
            gp:Create_command_Circle
          (T
            (alert (strcat "ObjectCreationStyle in function gp:calculate-Draw-TileRow"
                           "\nis invalid. Contact developer for assistance."
                           "\n        ObjectCreationStyle set to ACTIVEX"
            (setq ObjectCreationStyle "ACTIVEX")
  ;; Draw the circles to the left of the center.
  (while (< (distance startPoint tileCenterPt) HalfWidth)
    ;; Add each tile to the list to return.
    (setq tileList
          (cons
            (ObjectCreationFunction tileCenterPt TileRadius)
            tileList
    ;; Calculate the center point for the next tile.
    (setq tileCenterPt
          (polar tileCenterPt angp90 TileSpacing)
  );_ end of while
  ;; Draw the circles to the right of the center.
  (setq tileCenterPt
        (polar firstCenterPt angm90 TileSpacing)
    (setq tileList
          (cons
            tileList
    (setq tileCenterPt
          (polar tileCenterPt angm90 TileSpacing)
  );_ end of while
  ;; Return the list of tiles.
  tileList
) ;_ end of defun
AutoLISP 代码逻辑遵循伪代码,并添加了以下内容:
(setq ObjectCreationFunction
  (cond
    (T
      (alert
        (strcat
         "\nis invalid.  Contact the developer for assistance."
        ) ;_ end of strcat
      ) ;_ end of alert
  ) ;_ end of cond
) ;_ end of setq
还记得允许用户使用 ActiveX、函数或函数绘制图块(圆圈)的规范吗?变量被分配三个函数之一,具体取决于参数(从和通过传递)。下面是将在 gpdraw.lsp 中定义的三个函数:entmakecommandObjectCreationFunctionObjectCreationStyle C:GPath gp:Calculate-and-Draw-Tiles
(defun gp:Create_activeX_Circle (center radius)
  (vla-addCircle *ModelSpace*
    (vlax-3d-point center) ; convert to ActiveX-compatible 3D point
    radius
) ;_ end of defun
(defun gp:Create_entmake_Circle	(center radius)
  (entmake
    (list (cons 0 "CIRCLE") (cons 10 center) (cons 40 radius))
  (vlax-ename->vla-object (entlast))
(defun gp:Create_command_Circle	(center radius)
  (command "._circle" center radius)
第一个函数使用 ActiveX 函数绘制一个圆,并返回一个 ActiveX 对象。
第二个函数使用 绘制一个圆。它返回转换为 ActiveX 对象的实体名称。entmake
第三个函数使用 绘制一个圆。它还返回转换为 ActiveX 对象的实体名称。command
GMT+8, 2026-11-13 14:02
