剪辑边界示例
2024-5-18 17:57| 发布者: admin| 查看: 1510| 评论: 0|原作者: admin|来自: AutoCAD
剪辑边界示例
在以下示例中,在绘制任何内容之前,剪辑边界被推送到剪辑边界堆栈上,并在此对象的绘制完成后再次弹出:
Adesk::Boolean
MyObject::subWorldDraw(AcGiWorldDraw* pDraw)
    AcGiWorldGeometry * pGeom = &pDraw->geometry();
    pGeom->pushModelTransform(myTransform());
    AcGiClipBoundary cb;
    cb.m_bDrawBoundary	= true;
    cb.m_vNormal = AcGeVector3d::kZAxis;
    cb.m_ptPoint = AcGePoint3d::kOrigin;
    // Two points treated as a rectangle, three creates a triangle
    cb.m_aptPoints.append(AcGePoint2d(0,0));
    cb.m_aptPoints.append(AcGePoint2d(5,5));
    // We are clipping in our own space
    cb.m_xToClipSpace.setToIdentity();
    cb.m_xInverseBlockRefXForm = myTransform().inverse();
    // No Z clipping
    cb.m_bClippingBack = cb.m_bClippingFront = false;
    cb.m_dFrontClipZ = cb.m_dBackClipZ = 0.;
    Adesk::Boolean bPopClipBoundary = pGeom->pushClipBoundary(&cb);
    // Draw something
    pGeom->circle(...);
    pGeom->popModelTransform();
    if(bPopClipBoundary){ pGeom->popClipBoundary(); }
    return true; // world-only
由于此裁剪是一项复杂的操作,因此某些 AcGi 实现可能不完全支持它。在这种情况下,AcGi 实现可能会从 返回 false,并且不应调用 。pushClipBoundary()popClipBoundary()
GMT+8, 2026-10-28 18:56
