示例 4:计算要绘制的圆
2024-5-18 17:57| 发布者: admin| 查看: 871| 评论: 0|原作者: admin|来自: AutoCAD
示例 4:计算要绘制的圆
以下示例绘制一个以原点为中心的单位圆。绘制的确切圆取决于视口的圆视图。目标是用具有最少可辨别线段数的折线绘制一个圆。使用 VPORTS 命令,您可以创建四个视口,然后单击其中一个视口并放大圆圈,然后单击另一个视口并从中备份。执行 REGENALL 时,每个视口都会计算其自身的圆的最小分段折线表示。
这就是该示例计算折线中必要线段数的方法。首先,给定一个半径为给定半径的圆,该圆以原点为中心并位于 XY 平面中,并给定一条半径为 0.5 像素处与 X 轴相交的垂直线,确定 X 轴与从原点延伸到垂直线与圆相交点的线段之间的角度。两个 pi 除以这个角度提供了折线看起来像圆所需的最小线段数。用户将无法区分构成圆的各个线段,因为视觉差异小于一个像素。
      Adesk::Boolean
      AsdkTesselateSamp::subWorldDraw(AcGiWorldDraw *pW)
      // Draw a red 1       x 1 drawing-unit square centered at the
      // world       coordinate origin and parallel to the XY-plane.
      const       Adesk::UInt32 num_pts = 5;
      AcGePoint3d       verts[num_pts];
      verts[0] =       verts[4] = AcGePoint3d(-0.5, -0.5, 0.0);
      verts[1] =       AcGePoint3d( 0.5, -0.5, 0.0);
      verts[2] =       AcGePoint3d( 0.5,  0.5, 0.0);
      verts[3] =       AcGePoint3d(-0.5,  0.5, 0.0);
      pW-       >subEntityTraits().setColor(kRed);
      pW->geometry       ().polyline(num_pts, verts);
      // If regenType       is kAcGiSaveWorldDrawForProxy then we
      // must return       Adesk::kTrue, otherwise we need to return
      //       Adesk::kFalse to trigger calls to our viewportDraw().
      return (pW-       >regenType() == kAcGiSaveWorldDrawForProxy);
      void
      AsdkTesselateSamp::subViewportDraw(AcGiViewportDraw *pV)
      static double       two_pi = atan(1.0) * 8.0;
      // Get the       number of pixels on the X- and Y-edges of
      // a unit       square centered at (0.0, 0.0, 0.0), in
      // world       coordinates.
      AcGePoint3d       center(0.0, 0.0, 0.0);
      AcGePoint2d       area;
      pV->viewport       ().getNumPixelsInUnitSquare(center, area);
      // If the       'area' values are negative, then we are in
      // perspective       mode and the 'center' is too close or
      // in back of       the viewport.
      if (area.x >       0.0) {
      // Print out       the number of pixels along the
      // y-axis of       the unit square used in
      //       getNumPixelsInUnitSquare.
      AcGeVector3d       norm(0.0, 0.0, 1.0);
      AcGeVector3d       dir(1.0, 0.0, 0.0);
      TCHAR buf[100];
      _stprintf(buf,       _T("%7.3lf"), area.y);
      pV->geometry       ().text(center, norm, dir, 1.0, 1.0,
      0.0, buf);
      // Draw a       circle that depends on how big the circle
      // is in the       viewport.  This is a problem of
      // figuring out       the least number of segments needed
      // by a       polyline so it doesn't look segmented.
      // By the way,       the worldDraw() and viewportDraw() of
      // an entity in       a viewport are only called during a
      // regen and       not necessarily during a ZOOM or PAN.
      // The reason       is that a REGEN produces something
      // akin to a       very high resolution image internally
      // that AutoCAD       can zoom in or pan around,
      // until you       get too close to this image or any of
      // its edges --       at which point a REGEN is internally
      // invoked for       that viewport and a new internal
      // image is       created (ready to be mildly zoomed and
      // panned       upon.)
      double radius =       0.5;
      double       half_pixel_hgt = 2.0 / area.x; // in world
      // coords
      int num_segs =       8;
      double angle =       two_pi / num_segs;
      if       (half_pixel_hgt > radius / 2) {
      // The circle       is around or less than the size
      // of a pixel.       So generate a very small octagon.
      num_segs = 8;
      } else {
      // Given a       circle centered at the origin of a
      // given       'radius' in the XY-plane, and given a
      // vertical       line that intersects the X-axis at
      // 'radius -       half a pixel', what is the angle
      // from the X-       axis of a line segment from the
      // origin to       the point where the vertical line
      // and the       circle intersect?  Two pi divided by
      // this angle       gives you a minimum number of
      // segments       needed by a polyline to 'look' like
      // a circle and       not be able to differentiate
      // the       individual segments because the visual
      // differences       are less than the size of a
      // pixel.       (This is not the only way to figure
      // this out but       it's sufficient.)
      angle = acos       ((radius - 1.0 / (area.x / 2.0))
      / radius);
      double       d_num_segs = two_pi / angle;
      // Limit the       number of segments from 8 to
      // 128 and use       whole numbers for
      // this count.
      if (d_num_segs       < 8.0) {
      num_segs = 8;
      } else if       (d_num_segs > 128.0) {
      num_segs = 128;
      } else {
      num_segs =       (int)d_num_segs;
      // Calculate       the vertices of the polyline from the
      // start,       around the circle, and back to the start
      // to close the       polyline.
      angle = 0.0;
      double       angle_inc = two_pi / (double)num_segs;
      AcGePoint3d*       verts = new AcGePoint3d[num_segs + 1];
      for (int i = 0;       i <= num_segs; i++,
      angle +=       angle_inc)
      verts[i].x =       center.x + radius * cos(angle);
      verts[i].y =       center.y + radius * sin(angle);
      verts[i].z =       center.z;
      pV->geometry       ().polyline(num_segs + 1, verts);
      delete []       verts;
  1. 转换示例
GMT+8, 2026-10-28 00:01
