示例 2:确定标准显示对象的隐藏线
本示例显示一个金字塔,前边缘为黄色,后边缘为蓝色,让您了解金字塔的可见边缘和隐藏边缘。该示例演示如何应用模型到眼睛的变换,然后应用透视变换。它使用眼坐标来绘制实体,并显示 、 、 、 、 和 的用法。isPerspective()doPerspective()getFrontandBackClipValues()polylineDc()polylineEye()polyline() 将眼坐标线段转换为显示空间
如果使用 的 、 、 或函数 ,则应调用 来建立实体的边界框。这将使 AutoCAD 知道图元需要多少空间,并在 ZOOM 范围中使用了多少空间。当实体位于世界坐标中时,通常会调用该函数,以确定在世界坐标中适合实体的最小框。polygonEye()polygonDc()polylineEye()polylineDc()AcGiViewportGeometryAcGiWorldGeometry::setExtents()setExtents() AsdkViewGeomSamp::AsdkViewGeomSamp() : mNumVerts(4)
mVerts[0] = AcGePoint3d(0.0, 0.0, 0.0);
mVerts[1] = AcGePoint3d(1.0, 0.0, 0.0);
mVerts[2] = AcGePoint3d(0.0, 1.0, 0.0);
mVerts[3] = AcGePoint3d(0.0, 0.0, 1.0);
Acad::ErrorStatus
AsdkViewGeomSamp::subTransformBy(const AcGeMatrix3d &xfm)
assertWriteEnabled();
for (Adesk::UInt32 i = 0; i < mNumVerts; i++) {
mVerts[i].transformBy(xfm);
return Acad::eOk;
Adesk::Boolean
AsdkViewGeomSamp::subWorldDraw(AcGiWorldDraw* pW)
// Draw a pyramid.
// If this is the REGULAR ACAD DISPLAY mode,
if (pW->regenType() == kAcGiStandardDisplay) {
// from each viewport's vantage point, figure out
// which sides of the pyramid are visible,
// then draw the visible ones yellow and the hidden
// ones blue.
// Set the extents of the pyramid here because
// AcGiViewportGeometrys polylineEye() doesnt
// set extents.
AcGePoint3d pt[2];
pt[0] = mVerts[i];
pt[1] = mVerts[(i + 1) % mNumVerts];
pW->geometry().setExtents(pt);
return Adesk::kFalse; // Call viewport draws.
// Otherwise give HIDE, SHADE, RENDER, or Proxy Graphics
// a pyramid with filled faces.
const Adesk::UInt32 faceListSize = 16;
static Adesk::Int32 faceList[faceListSize] = {
3, 0, 1, 2,
3, 0, 2, 3,
3, 0, 3, 1,
3, 1, 2, 3
pW->geometry().shell(mNumVerts, mVerts, faceListSize,
faceList);
return Adesk::kTrue; // Do NOT CALL viewportDraw.
void
AsdkViewGeomSamp::subViewportDraw(AcGiViewportDraw* pV)
// For this viewport, draw a pyramid with yellow
// visible lines and blue hidden lines.
// Get this viewport's net transform. This transform
// includes this entity's block transforms and this
// viewport's view transform; it does not include the
// perspective transform if we're in perspective
// mode -- that currently has to be applied separately
// when in perspective mode.
AcGeMatrix3d modelToEyeMat;
pV->viewport().getModelToEyeTransform(modelToEyeMat);
// Get the pyramid's vertices.
AcGePoint3d A = mVerts[0];
AcGePoint3d B = mVerts[1];
AcGePoint3d C = mVerts[2];
AcGePoint3d D = mVerts[3];
// Convert them to the viewport's eye coordinates.
A.transformBy(modelToEyeMat);
B.transformBy(modelToEyeMat);
C.transformBy(modelToEyeMat);
D.transformBy(modelToEyeMat);
// Save the eye coordinates.
AcGePoint3d AEye = A;
AcGePoint3d BEye = B;
AcGePoint3d CEye = C;
AcGePoint3d DEye = D;
// Perform the perspective transform if necessary.
if (pV->viewport().isPerspective()) {
pV->viewport().doPerspective(A);
pV->viewport().doPerspective(B);
pV->viewport().doPerspective(C);
pV->viewport().doPerspective(D);
// From that view, figure out which faces are
// facing the the viewport and which are not.
int which_faces;
which_faces = ((C - A).crossProduct(B - A)).z
> 0.0 ? 1 : 0;
which_faces |= ((D - A).crossProduct(C - A)).z
> 0.0 ? 2 : 0;
which_faces |= ((B - A).crossProduct(D - A)).z
> 0.0 ? 4 : 0;
which_faces |= ((B - D).crossProduct(C - D)).z
> 0.0 ? 8 : 0;
// Those edges that meet between two faces that are
// facing away from the viewport will be hidden edges
// so draw them blue; otherwise, they are visible
// edges. (This example is incomplete as the test is
// indeterminate when the face is edge-on to the
// screen -- neither facing away or toward the screen.)
// Draw the 6 edges connecting the vertices using eye
// coordinate geometry that can be back and front
// clipped.
AcGePoint3d verts[2];
Adesk::UInt16 color;
// AB
color = which_faces & 0x5 ? kYellow : kBlue;
pV->subEntityTraits().setColor(color);
verts[0] = AEye;
verts[1] = BEye;
pV->geometry().polylineEye(2, verts);
// AC
color = which_faces & 0x3 ? kYellow : kBlue;
verts[0] = AEye;
verts[1] = CEye;
// AD
color = which_faces & 0x6 ? kYellow : kBlue;
verts[0] = AEye;
verts[1] = DEye;
// CD
color = which_faces & 0xa ? kYellow : kBlue;
verts[0] = CEye;
verts[1] = DEye;
// DB
color = which_faces & 0xc ? kYellow : kBlue;
verts[0] = DEye;
verts[1] = BEye;
// BC
color = which_faces & 0x9 ? kYellow : kBlue;
verts[0] = BEye;
verts[1] = CEye;
父主题: |
GMT+8, 2026-11-15 11:55
